Does anyone know of a page or way to view VS* variables without having to store them in a VC* variable?
There is not a way to display system variables without transferring them to common variables. That being said, some of them have their won display pages such as zero set variables, Zero Shift variables, tool offsets, tool radius etc.. Which system variables are you trying to display and why? We may be able to help you depending on what you are trying to accomplish.
Best regards,
The system used common variables Eg VS1 to VS200
Please clarify.
We have HMC mill's with p200 and p300 controls. Some of the variables i use are the common variables that are there for system to use. I guess like system global variables.
Code:OTCHG (START CHANGE TOOLS) CALL OANTL (FIND TOOL NUMBERS) IF [PNT NE EMPTY] N10 PNT=0 N10IF [VS200 NE PAT] N50 IF [VS199 EQ PNT] NRTS N50IF [VS199 EQ 0] N100 IF [VS199 EQ PAT] N100 M64 N100CALL ONGPS PAT=PAT (CHECK NG TOOL PAUSE) T=PAT M6 N150IF [PNT EQ 0] N200 IF [VTLD3[PNT] GT 10] N200 T=PNT N200 NRTS RTS
There just like common variables but there used by aftermarket addons so they don't have to use up common (VC) variables to store things.
There nice in some ways because you can't change them from the common variables page. We used to have a guy that would write zero's to the common variables every night because he said he didn't like that they didn't all match.
When he did that the machine would alarm out because my subprograms would lose there data.
hy rdhoggattjr
this code works on osp300L :There just like common variables but there used by aftermarket addons
VS* may be sometimes like common variables, but it is indeed much more :Code:NOEX V1 = 0 $ VS099 = 111111 $ VS99 = 222222 $ V1 = VS099 ( v1 will be 222222 )
... VSET : is like an instruction, allowing to declare variables inside sdf
... VCAC* : is like a boolean, returning spindle state : S or C mode
... VS27, VS28, VS29, VS30 : is like a common variables, inside renishaw probing macros
- system variables are linked with the controller; they are initialized by it
- common variables are not linked with the controller; they are not initialized by it, but by the user / programmer
when you use VS* like that, you are entering an area that may be protected, so you have to be sure:
... that the controller is not using those syntaxes, or
... that the controller is using those syntaxes, but the way that you are using them is not interfering with the controller
to avoid such potential dangerous situations, then use common variables, or local variables ( they can no be changed from an input panel )
your program has a few types of variables :
... system variables VTLD3
... local variables PAT , PNT
... off limit ( system or local ) : VS199 , VS200
if possible, use a single type of variable
pls be aware:
... about PAT , PNT : until a while ago, it was not allowed to use local variables that begin with P
... about VS199, VS30 : is not allowed to use local variables that begin with V
that code that you shared, is a lucky hit, or created by someone who knows the interferences
system variables are globalI guess like system global variables
that seems to be a tool change macro, that uses also tool groups ; why do you need to lock the variables, so to make it work ? why do you can not rely on common variables ?We used to have a guy that would write zero's to the common variables every night because he said he didn't like that they didn't all match.
whatever exception exists, it must be handled by the code, and the code itself should stand-alone, whatever the common variables values are ...
there is an exception case with your code, so you wish to avoid common variables : what is that exception ?
also, somewhere, i believe you lose traking the data, so you need to read the VS* value / kindly![]()
It is a tool change macro. This macro is about three levels in, but in an older version of my subs I use to store current and next tool numbers in VC variables and they would set them to zero.
That's why I switched to using VS variables for some things.
Before I use any I search through both the Renishaw probing macros and the Okuma probing macros to make sure that there not using them.
if the program will be there for :
... a while, i store actual and next, inside the program
... a short time, i no longer bother with the next tool ( no more prestaging tools )
if you have 10+ tools, you will edit 10 variables ? or 10 actuals + 10 next, and how you manage it inside the program ?
why don't you edit the program ? kindly![]()
We use the variables to store characteristics about the tools, like default tool lengths, number of flutes, tip radius, diameters and more. It's all used to run auto tool measurement and tool breakage detection on our pallet system machines. They get updated through txt files at tool changes.
okey, so there is more then a tool change macro
tool length & diameter : good when measuring
radius : for comp codes
please, where/how do you use the "number of flutes" characteristic ? and what other characteristics are you using ? and what type of tool measuring system are you using ?
please, will you share such a file ?They get updated through txt files at tool changes.
now, back to you : if you send data, in order to auto-measure or detect broken tools, why do you still need to check the vs** variable value ? i mean, is like you are one step ahead, with tool preparation/measure/detect, but you are one step behind with the tool change macro ...
i am sorry, i can not help you : you can not check the system variable value directly ( unless you store it in a file, or record it inside a common variable ), and i also can not sugest you a solution, or an alternative, because i can't locate the problem
i believe that there is something that you can speed up, so to avoid checking the vs**, but i need more details / kindly![]()
It was just for faster debugging of the macros.
I use number of flutes for measuring face mills and inserted tools that I don't want to spin to find high flutes. I also need flute angle to spindle orientation for tool alignment in the holder. The system is a mixture of Okuma and Renishaw macros depending on how it needs to measure the tool.
I believe the answer is no.
Under gauging results is the only place i'd expect to find them if anywhere, but i haven't looked in that screen for a while and i don't have a mill handy to check.
That said, there is a note in the gauging manual which states:
*under "common variables for storing gauging cycle results"*
"Note that referencing of the common variables indicated above is not allowed in the usual common
variable reference method. To use the data stored in these common variables, move it to other
common variables that can be referenced.
To reference the end face gauging result in the X-axis direction, move the data to VC1, for example,
by specifying “VC1 = VS29”, then read common variable VC1 in a part program."
So with at least 99% confidence, the answer is no.
That said, depending on the control series, i'm not sure if the VS variables are variables which can be read via the API using an app.
If you can do that, you can read them and post the values to a spreadsheet looking screen to display them, think AutoComp. Though i'm not an app writer or software programmer.
Another stop gap, depending on the control series, is that you can store VS variables to local variables.
Local variables can be displayed on some of the newer series of OSP controls.
Therefore you'd have:
NUM1=VS2
NUM2=VS5
and though you wouldn't be able to display VS2 or VS5 directly and real time, you could view it sort of using local variables.
Hope that answers that for ya.
if you wish to debug the macro, simply write down the values that you wish; try this, it separates the values with tabs, so you can paste the content inside *.xls :
i hope it helpsCode:ODD ( data dump ) ( call it from within the tool change macro, or close to it ) FWRITC data.txt;A NOEX PUT VS200 PUT ' ' PUT VS199 PUT '' PUT PAT PUT '' PUT PNT WRITE C CLOSE C RTS
i was a bit confused ... i believed that you wish to use common variables all the time, so to input actual and next tool, from the cnc panel; now, that you only wish to debug, it makes more sense
however, even so, i believe that you could use only common variables, and make the program work, even if someone edits the common variables from the panel : it should work, as long as you initialize the variables from within the program; well, if someone changes them during a tool change sequence, then, you know, bad luckbut still, this does not happen often ...
please, can you explain this a bit ? for example, if you have a tool dia80, z6, you will somehow measure the angle between the tool and the toolholder, so to know the orientation angle of the spindle, so to measure it directly at it's highest point ?I use number of flutes for measuring face mills and inserted tools that I don't want to spin to find high flutes.
please, explain a bit moreI also need flute angle to spindle orientation for tool alignment in the holder.
also, from that file : what is 1337, FL , ROT , TI , BRLI , B , S , R , RD1 , RD2 , RD3 ? kindly![]()
please, can you explain this a bit ? for example, if you have a tool dia80, z6, you will somehow measure the angle between the tool and the toolholder, so to know the orientation angle of the spindle, so to measure it directly at it's highest point ?We have some large tools (8" reamers and 6" facemills) that we don't spin when we measure them because they are that big. So the machine takes the number of flutes and rotation of the body of the face mill to check each flute for the highest one and uses that as the length offset.
machine number, number of flutes, rotation of flutes, cut time before auto measurement, amount of tool breakage before tool is considered broke, check for breakage, spin tool during measurement, swap tool on tool life time out, and RD1, RD2 and RD3 are redundant tools that it can swap too.
hy, is it ok for you to use the fwritc, so to debug your soubroutine ? do you need something else ? you could also use :
... local variables, and check a table that displayes them; pls check post 27 : https://www.cnczone.com/forums/okuma...variables.html
... common variables, check their value, and when is all ok, switch back to VS*
nice jobBefore I use any I search through both the Renishaw probing macros and the Okuma probing macros to make sure that there not using them.did you looked into the msb files ?
however, when you use a custom name variable, a custom syntax, there are restrictions :
... no function names, no comparison or boolean operators
... no extended addres characters
... no reserved local variable words
... no local variables that begin with O, N or V
* possibly others; if you are intersted, check the list below
if somehow you enter inside a conflict area, you should not worry as long as you know that you don't interfere with the control; for example, i have messed with the oo30 inside the msb, and some VS variables, also inside the msb file, so to ' tune ' a few things
8" reamer ? is it a bt30 machine ?We have some large tools (8" reamers and 6" facemills) that we don't spin when we measure them because they are that big. So the machine takes the number of flutes and rotation of the body of the face mill to check each flute for the highest one and uses that as the length offset.if i may, is it going inside a blind, or a through hole ? and why don't you use a simpler tool, like an excentric ?
so tools with flutes are aligned, rotary, in respect to spindle orientation ... nice job
i guess you are using a renishaw touch setter, not a fancy laser ...
what about avoiding in machine-measurement ? have you considered that ? you could tranfer offset values inside the machine, and only measure, in order to detect if it's broken; like this, you could avoid the in-machine measuring time ... or you wish to target directly a finishing dimension ? you don't probe, and recut ? only one cut, and that's it ? just asking ...
kindly
Code:
1A 1B 2A 2B AA AB ABS ACOS AG AN AND ARC ASIN AT AT ATAN ATAN2 BA BC BCD BHC BIN BOUNS BR BT CALL CAMCV CASCME CASCTL CB CC CD CF CHD CHFC CHFR CL CLEAR CLOSE CONEI CONEO COPY COPYE COS CP CQ CR CT DA DA DB DB DC DEF DELETE DFIX DFUP DGRDX DGRDY DO DRAW DROUND DS EMPTY END EOR EQ FA FA FB FB FC FI FIX FMILF FMILR FOPENA FOPENB FUP FW FWRITC GE GET GOTO GRCI GRCV GRDX GRDY GRER GROF GRON GRSK GRST GT HA HA HB HC HI HJ HK HORN HP HS HS IA IB IF KA KA KB KB KW LA LAA LB LCONI LCONO LD LE LK LMV LMW LPRINT LT LW MD MG MGS MITCAN MN MOBOR MOD MODIN MODOUT MODRL MODSF MOEND MOPLD MOREM MOTAP MSG MT MTM MTS NE NOT NP OF OG OR OS PA PCIR PMIL PMILR PREG PRINTF PRMDI PRMDO PRSOL PTANXT PTPRET PTRETT PUT PW PX PXD PXE PXF PZ PZD PZE PZF QA QA QB QC QD RA RB RC RCIRI RCIRO READ RGEND RH RH RI RJ RLDPN RM RMILI RMILO ROUND RP RS RSQCO RSQRI RSQRO RSTRT RT RT RTI RTMCR RTMDI RTS RW SA SAVE SB SB SC SC SCALL SCALLE SCALLS SCALLSE SCRIPT SIN SLOAD SP SPHRI SPHRO SPRINT SPRINTF SQRT SQRX SQRY SS SYNC TA TAN TANXT TAPR TB TC TD TDG TE TFA TFB TFC TFP TFQ TFR TG TG TH THEN TL TLCO TLFOFF TLFON TLFR TLOK TM TN TN TP TPRET TR TRDL TRDT TRETT TS TSG TT TW UA UB WA WB WHILE WP WRITE WW XA XB XD XE XF XS ZA ZB ZD ZE ZF
Thank you for the info
I came across that thread in my search. interesting read. I don't deal in lathes much so it was neat to see some of the diffences between the two.
Yeah
I have done the same, but I saved the msb macros to another file and changed "OO30" and so on to "OT30" as to not mess with the factory msb'sif somehow you enter inside a conflict area, you should not worry as long as you know that you don't interfere with the control; for example, i have messed with the oo30 inside the msb, and some VS variables, also inside the msb file, so to ' tune ' a few things
CAT50. Through hole in cast iron. We moved the parts from another machine that was giving fits and didn't want to retool.8" reamer ? is it a bt30 machine ?if i may, is it going inside a blind, or a through hole ? and why don't you use a simpler tool, like an excentric ?
so tools with flutes are aligned, rotary, in respect to spindle orientation ... nice job![]()
Yes. From what I have heard lasers can mismeasure if there is lint or even coolant on the tool.i guess you are using a renishaw touch setter, not a fancy laser ...
The machine remeasures at the same time as checking for breakage if the tool has enough cut time on it, otherwise it just checks if it is broke.what about avoiding in machine-measurement ? have you considered that ? you could tranfer offset values inside the machine, and only measure, in order to detect if it's broken; like this, you could avoid the in-machine measuring time ... or you wish to target directly a finishing dimension ? you don't probe, and recut ? only one cut, and that's it ? just asking …
please, what is the difference between ot30 and oo30 ? this ot30, did you stored it inside a lib file, or inside a msb file ? kindlyI have done the same, but I saved the msb macros to another file and changed "OO30" and so on to "OT30" as to not mess with the factory msb's![]()
I made it to where the tool can spin at recommended speeds and feeds in the Renishaw manual for our probes. But I later found out there is a way to make it spin with standard Okuma macros. https://www.cnczone.com/forums/okuma...ubprogram.html
Its's in an SSB file.
hy, i am dealing these days with local variables, and i remembered this thread
VS are local variables ( flashed on reset ), array type : for example, VS00001 = 1 and VS1 = 1 will target same variable, while VS[1] won't work; being an array type, means that the variable is created at system power on, by default, thus VS should never be empty
if you wish, i have some programs for reseting, backing up, etc ... onestly, i have some days when i hate to see a common variable <>0; yeah, i know ...We used to have a guy that would write zero's to the common variables every night because he said he didn't like that they didn't all match.
also, use this to boost your code; more stuff can be done / kindly
Code:OTCHG (remove comments) CALL OANTL IF [PNT NE EMPTY] N10 NOEX PNT=0 N10IF [VS200 NE PAT] N50 IF [VS199 EQ PNT] NRTS N50IF [VS199 EQ 0] N100 IF [VS199 EQ PAT] N100 M64 N100CALL ONGPS PAT=PAT (*1) T=PAT M6 N150IF [PNT EQ 0] NRTS IF [VTLD3[PNT] GT 10] NRTS T=PNT NRTS RTS (*1 maybe it does not matter now, but PAT=PAT is not required on lathes, because local variables, once created, are available on all following/child nesting levels )
