Not much been happening lately.
Got the head fitted. Likely to be only temporary while I make a thin spacer that tapers by 0.16mm. This is roughly how much the head needs tilting to get both column and head at 0.0mm alignment. At the moment the column is tilted back that much to get the Y axis in tram but the Z height varies a fair bit over 100mm travel.
Also finally got some doors on.
This below turned out better than I thought. It's the little things
A level for the coolant tank (litres).
