I don't understand, are you trying to run the motor at 50 Hz? If so it will soon be burnt out. Minimum low speed under no load should never be less than 100 Hz. Mine is set at 150.
Retired Master Electrician, HVAC/R Commercial. FLA Saturn 2 4x4 CNC Router Mach4 Kimber 1911 45ACP
