588,285 active members*
4,491 visitors online*
Results 1 to 6 of 6
    Sep 2007
    12
    New Spindle drive Boxford V190 VMC
    Happy with my old Boxford 190VMC, but would like to do some tapping on it.
    at present cant reverse spindle the set up is as follows.
    Spindle drive is EVD534-E LENZE the BOB is hooked up to DIYCNC Spindle V4 board, not sure what the motor is, assume its the original from boxford 450w one.
    the wiring on bob is setup for reversing but when you input M3 S whatever, spindle turn on CW, when input M4 S whatever, spindle stops and starts same way CW, does not reverse.
    Is there a way to enable spindle reversing on above setup? or do I need to buy a new Spindle Kit? ie spindle drive + control board + spindle motor.
    Mike
    Apr 2005
    305
    Re: New Spindle drive Boxford V190 VMC
    Have you cheched datashet of your spindle drive? Page 30.
    http://www.lenze.org.ua/pdf/530_Spee...rs_1202_EN.pdf
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
    Sep 2007
    12
    Yes I did see that, but the relays on the spindle v4 board have no wires going into them. and when I put a volt meter on them only one relay has voltage on it.
    the relays are not wired up.
    MikeAttachment 427604Attachment 427604
    Sep 2007
    12
    Quote Originally Posted by moso View Post
    As the LENZE has no stop/ccw or stop/cw input do I just rout 2 wires from the motor through the relays?
    if so can someone do me a sketch of the wiring pls.
    Sep 2007
    12
    Or can I use this to reverse spindle
    https://www.ebay.co.uk/itm/5V-9V-12V...YAAOSwsPhdghbQ
    also found this diagram
    15362
    Just like the FWD direction it has a Relay connected to S2 for reverse you need another active Relay that connects to S3
    So if you have 2 Relays on your Breakout board you need to get both working with M3 and M4 then connect to the S3 Terminal for the Reverse direction
    Mactec54
  1. Replies: 1
    Last Post: 10-20-2018, 04:27 AM
  2. I.H. Belt drive conversion spindle drive sleeve gear
    By Roadstercycle in forum RF-45 Clone Mill
    Last Post: 04-23-2018, 12:43 AM
  3. Boxford TCL160 Spindle motor wire identification.
    By Georgie in forum Benchtop Machines
    Last Post: 02-10-2017, 05:38 PM
  4. Boxford TCL160 interface to Mitsubishi Freqrol drive and a few other questions
    By M100 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-24-2009, 12:58 AM
  5. Mach3 spindle control of Boxford 260 VMC
    By jwhitley in forum Benchtop Machines
    Last Post: 09-09-2008, 06:21 PM
