588,513 active members*
4,708 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > Dinosaur skeleton, and other models, DXF files.
Page 5 of 224 345671555105
Results 81 to 100 of 4471
  1. #81
    Mar 2004
    204
    I had the same result. Looks like those two files are missing from the server or the links are bad.
  2. #82
    Oct 2004
    727
    OK, I give up, what kind of wood is everyone using to cut these 3D puzzles out of? I've been looking for some kind of nice looking 'whitish' wood sheeting approx. 1/8" or 3mm thick and 12" x 24" or larger in size but have been unable to find a source, local or other in the USA. Maybe I'm using the wrong search parameters or looking in the wrong stores (Lowe's, Home Depot, Hobby Shops, etc.).
    I was thinking about cutting a bunch of these critters out for my daughter's classmates for Christmas presents but am quickly running out of time.
    Anyone???
    HayTay
    Don't be the one that stands in the way of your success!
  3. #83
    Feb 2004
    2337
    Use MDF and then spray it white.
    Cheap, quick, and simple.
    Or maybe plastic.
  4. #84
    Dec 2004
    62
    Went to the local Harbor Freight today and the had several dinosaur puzzles for 99 cents. Not to distract from making them yourself at the price one could buy them and somehow put them into a DXF file and cut whatever size one wanted. If and had the know how and the equipment I think I would do it. I've really enjoyed the posts here as well as throughout the ZONE, and one day hope to get a CNC machine up and running.
    Herman
    Disclaimer: Not affiliated with any company or business. Happily Retired.
  5. #85
    May 2005
    362
    Don't try to open the file. You want to "save as" or what ever command your browser uses for saving the target file.
  6. #86
    Mar 2004
    204
    If your cutting these with either a 1/16" or 1/8" endmills, using a high speed spindle like from a router, in 1/8" (3mm) material (MDF), what feedrates are you guys using and are you able to cut it in one pass or are you making multiple depth passes? I would imagine multiple passes would be required, especially with a 1/16" cutter.
    Carl
  7. #87
    May 2006
    2420
    Quote Originally Posted by HayTay View Post
    Anyone???
    Dunno bout everyone, but I am using thin ply, 3.6mm, it is fairly strong, cheap and doesn't look all that bad when finished. Guess you could apply sanding sealer and paint. I got the stuff with a smooth finish. Another option would to "lime wash" the timber.
    I had similiar ideas to make a few for christmas for the kids, funny I spent the last 6 months building my first router, now I have about a week to learn how to use it and make kids toys with it... ah well these skeleton animals are a pretty good way to get used to the machine and what it can do.
    I have learned that you have to be careful that all the lines are actually joined in the DXF's before you make the g-code, or things get a little crazy.
    Russell.
  8. #88
    Oct 2005
    74
    my jurassic park, my velociaptor with a small change in the archive now is running, and shark does not need glue
    Attached Thumbnails Attached Thumbnails dino_apatossaiuro.jpg   cavalo_fogo.jpg   meu_jurasic_park_menor.jpg   velociraptor_correndo.jpg
  9. #89
    Mar 2004
    261
    That is really a nice collection! What software did you use to do the small sign? That is alot of pocket cutting. Good job!
    RipperSoftware
  10. #90
    Mar 2004
    204
    Very nice collection Jack. The Velociraptor is really cool. I need to get going and start cutting some myself. Missing out on all the fun.
  11. #91
    Oct 2005
    74
    [QUOTE=rippersoft;229890]That is really a nice collection! What software did you use to do the small sign? That is alot of pocket cutting. Good job!
    RipperSoftware
    I use artcam it
  12. #92
    Oct 2005
    74
    inneb! you can share that bird that this in its table of billiards
  13. #93
    Feb 2004
    2337
    As I have said in a previous post, the files are in the thread that whiteriver posted http://www.cnczone.com/forums/showpo...31&postcount=5
    they are a font that you type into your CAD program and then reaize it according to your needs. Quite cool actually.
  14. #94
    Oct 2005
    74
    Quote Originally Posted by ynneb View Post
    I know. my interest is only bird(i think) with the base in cross, these dinos in ttf I has here
    thanks
    a litle dinos again
    Attached Thumbnails Attached Thumbnails borboleta_acrilico.jpg   pterodatilo_.jpg   shark_acrilico.jpg   shark_acrilico0013.JPG
  15. #95
    Oct 2004
    727
    Well, I've found one answer to my question. While my wife and daughter wandered around PetSmart, I moseyed over to Michaels ("The Arts and Crafts Store"). Lo and behold!, I found 12" x 24" x 1/8" craft plywood (stock #0 91157 05306 3). Michaels carries other assorted sizes and thicknesses, too. It seemed to be kind of pricey at $3.99 US a sheet, but I purchased some anyway. I figured that a piece of plywood in the hand is worth two still in the forest.
    Now I can cut some of these 3D puzzles while I look for a less expensive source for the plywood.
    HayTay
  16. #96
    May 2005
    120
    Here are some examples of what I found at Harbor Freight as Dinosaurs:
  17. #97
    May 2005
    120
    Here are the Insects:
  18. #98
    May 2005
    120
    This is what the Plesiosaurus cuts looks like
  19. #99
    May 2005
    120
    This is what the Cricket cuts look like:
  20. #100
    May 2005
    120
    This is what the Ant cuts look like:
  1. Dinosaur Puzzle
    By Rosey Musick in forum Machine Created Art
    Last Post: 04-11-2013, 07:03 PM
  2. Dinosaur Trade
    By roninB4 in forum Diemaking / Diecutting
    Last Post: 11-18-2012, 03:01 PM
  3. Who will stop this china Dinosaur??
    By smtclman in forum News Announcements
    Last Post: 12-19-2010, 11:05 PM
  4. Epoxy Granite "s Skeleton
    By hkxy in forum Epoxy Granite
    Last Post: 05-03-2010, 02:35 AM
  5. Replies: 2
    Last Post: 03-09-2007, 08:47 PM
