O.k., I've got a 2.2 Kw inverter and a Piranha XL controller, is there any way to enable spindle on/off ?
I am not afraid to open the case of the controller, nor am I afraid to do some soldering, if I have to.
Any help would be GREATLY appreciated.
mactec54,
I believe I know the correct parameters for the VFD. Attached are three photos of the BOB (not pro quality, sorry).
The next wave I believe is a bad idea, you need a Relay to switch FOR and DCM on the VFD Drive if the Next wave has a spare output that could turn a Relay On /Off that is all you need I don't see a Relay on there Board
It's just a switch with no voltage on the Relay output
Mactec54
Thanks mactec54,
I think I have a relay that will work, I'll check it out.
