I just checked the voltage and it is at 241 volts between the 2 lines. The highest jumper goes from 221-240 and the transformer toward the bottom of the cabinet goes from 224-250
Since the voltage is at 241 that is 1 volt over what the jumper says. Could that cause the problem i am having? How do you correct the voltage?
