Re: Need some help, Machine not carving straight lines
Originally Posted by
Rschaeffer83
We tightened the jam nut as much as we could but there was still backlash. We are going to make a special washer to put between the jam nut and the black box.
Does anyone know if there is supposed to be any backlash at all? We were debating on whether or not it should be moving slightly.
Special washer ? If these are the type of blocks I'm thinking of there should be a part #4 as shown in the included jpeg.
The chinesium version of these blocks can have a small amount of backlash. On one sloppy block I resorted to a thin shim in-between the outer races. Not remotely as sloppy as shown in your video.
edit/ Where the thin shim mentioned is place depends on the reason for the slop.
