Hi all
I think I have a problem with my breakout board
It's a HG08 from cnc4you
X and Z axis working fine
But Y axis moves only one direction when using keyboard or when I hit tab and click on arrow direction using mouse,
I have checked all wiring,
Have checked all pins on serial cable,
Have swapped out serial cable for new one, but no difference,
But the HG08 board has a A axis output,
So I plugged my Y driver into the A axis on breakout board,
In pin and ports, motor outputs
I changed my Y axis step pin and dir pin to the
A axis,
Resigned my A axis hotkeys to where my Y axis hotkeys was
And it works fine now jogging it around the table,
But when I run a program Mach still thinks
the original Y axis is controlling the Y movement
But it's not,
So is there any way I can change Machs Y axis to run the A axis permanently,
Badly stuck I could buy a new breakout board
