587,299 active members*
3,867 visitors online*
Results 1 to 8 of 8
    Sep 2006
    25
    Question NEW M code for fanuc Oi
    I want to write a new M code to set a PMC out put .
    How can I do it ? which documents I should read?
    thaks
    Dec 2003
    24223
    Re: NEW M code for fanuc Oi
    This is done in the ladder.
    I can't recall if the 0i has an eprom like early 0 versions, but if so, you need an eprom burner and programmer.
    Al.
    Albert E.
    Dec 2009
    968
    the 0i series has its own FROM module where are the system files and the PMC.The changes ca be done in the machine soft,entering in the PMC and edit it .
    Sep 2006
    25
    Thanks for your reply
    I want to connect a barfeeder to our CNC machine is it possible to set an out put and read an Input of PMC in CNC program?
    Dec 2003
    24223
    The CNC and PLC side communicate via a bus called the BMI, where codes are passed either way, for the CNC to send to the PLC, F functions are used, for PLC to CNC, G codes are used.
    Al.
    Albert E.
    Sep 2006
    25
    Question Re: NEW M code for fanuc Oi
    Al.
    Thanks for your reply I AM LOOKING FOR cnc program instruction so I CAN READ pmc input and write to PMC OUT PUT
    thanks
    Jan 2014
    106
    I think what everyone is saying is that even if you had CNC program instructions you still need changes done in the PMC to make it all work.
    More than one signal will be needed to accomadate a bar feeder safely.
    Al_the_man has given you good instructions.
    Quite often decent MTB's will have additional Mcodes pre defined in the PLC usually a latched type or a oneshot. Barfeeder integration should be much more than just an m-code with alarm codes for faults as well.
    You would need software to decompile the fanuc PMC and knowledge of PLC ladder code.
    First step would be extracting the PMC from your 0i this is easiest done from the PMC menu, which version 0i do you have TB, TC, TD, TF, TF PLUS ?
    *~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~*
    *__________If you feel inclined to pay for the support you receive__________*
    *_______Please give to charity https://www.oxfam.org.au/get-involved/_______*
  1. Fanuc 0M G-Code Help
    By steven1970 in forum Fanuc
    Last Post: 02-19-2016, 11:54 PM
  2. Need help with G75 code on Fanuc 10
    By bobancurug in forum G-Code Programing
    Last Post: 10-26-2011, 08:24 AM
  3. Replies: 4
    Last Post: 03-29-2011, 02:39 PM
  4. fanuc program code vs. Haas code
    By sixty8frbrd in forum Fanuc
    Last Post: 03-11-2011, 04:05 AM
  5. Converting Fanuc G code to Seimens 840D G code
    By Jasbinder in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 02-20-2011, 05:02 PM
