587,104 active members*
4,287 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Setting up AMC BE25A20 in torque mode?
Page 2 of 2 12
Results 21 to 27 of 27
  1. #21
    Mar 2005
    271
    Re: Setting up AMC BE25A20 in torque mode?
    I have made up boards in the past very similar to this, I prefer to use Vero Strip Board Board and the other components from Digikey.
    Boards. half way down. https://www.futurlec.com/Protoboards.shtml
    Al.
    Thanks Alot.
  2. #22
    Mar 2005
    271
    Al.
    Thanks Alot The Man
  3. #23
    Mar 2005
    271
    Hey Sean for the drive fault out of the drive, where did you put it on the 7i77.
  4. #24
    Mar 2005
    271
    Hey Sean, where did you wire the drive fault into the 7i77 Mesa board.
  5. #25
    Mar 2005
    271
    Quote Originally Posted by CATCH22 View Post
    Thanks Sean, now all I have to do is figure out how to read electrical schematics. Lol
    I made one of these boards that Sean so kindly shared with me, but I can't figure out where the fault goes into the 7i77 board, can't see anything in the manual about it.
    If anyone can help me out I would really appreciate it.
    Thanks Mike
  6. #26
    Apr 2005
    72
    Thanks Mike
    Mike, I apologize, I must have missed the notification there was a reply in the thread. Did you get this figured out yet? I have each of the fault outputs from the board going into one of the 7i77 24VDC capable inputs. It really doesn't matter which one. I have that input pin then set as a fault for the axis in the hal configuration (IIRC I did that in pncconf). I know that isn't real specific. I can go grab the configuration from the machine if it would help.
    Sean
  7. #27
    Mar 2005
    271
    Quote Originally Posted by seanano View Post
    Sean
    Thanks Sean, but I have it up and running now.
    Thanks Mike
Page 2 of 2 12
  1. What is - Torque Mode? Position Mode? Speed/Velocity Mode?
    By sunmix in forum Servo Motors / Drives
    Last Post: 01-20-2024, 10:34 AM
  2. Speed vs. Torque mode
    By arvidj in forum Dynomotion/Kflop/Kanalog
    Last Post: 06-17-2013, 03:55 AM
  3. Step Response graph in Torque Mode
    By Dr.Nos in forum CNC Machine Related Electronics
    Last Post: 10-27-2012, 09:57 PM
  4. Torque Mode vs Velocity
    By K&T EB in forum CamSoft Products
    Last Post: 01-06-2010, 03:40 PM
  5. AMC BE25A20 drive in encoder velocity mode.
    By lucas in forum Servo Motors / Drives
    Last Post: 04-02-2009, 06:58 PM
