587,999 active members*
3,569 visitors online*
IndustryArena Forum > CAM Software > MadCAM > Strange movements
    Jun 2010
    4
    Strange movements
    Hi good day
    Hi good day
    I'm testing MadCam6 5 simultaneous axes
    i have a planar finish path 5 continuous axes in a ring
    but in the simulation the C axis rotates 180 degrees with each pass
    axis A does not advance from - to + and forces axis C to rotate
    I already configured the machine in many ways and it continues the same
    I appreciate the help of some
    version is Trial
    post Mach3 5 axis
    thank you very much for your help
    May 2006
    343
    Re: Strange movements
    Rotate part 90 degrees. Then generate your toolpaths
    Jun 2010
    4
    hello good morning thanks for answering
    I already rotated the piece 90 degrees and calculated the trajectories but it remains the same
    attach the file
    thanks
    May 2006
    343
    Try different toolpath strategies. Boundary from curves
  1. V28 mystery movements
    By Ben S in forum BobCad-Cam
    Last Post: 09-23-2015, 04:24 PM
  2. Strange movements when profiling simple rectangle
    By WallClimberUK in forum Mach Software (ArtSoft software)
    Last Post: 11-13-2014, 03:34 PM
  3. First movements......
    By bald9eagle in forum DIY CNC Router Table Machines
    Last Post: 08-25-2014, 05:38 PM
  4. Erratic movements, inconsistent action. uncontrolled movements
    By dusty41 in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 01-06-2014, 11:36 AM
  5. First machine, first movements
    By aarongough in forum DIY CNC Router Table Machines
    Last Post: 06-22-2011, 04:24 PM
