587,267 active members*
4,106 visitors online*
Thread: CNC Glossary
Results 1 to 18 of 18
    6855
    CNC Glossary
    I'm going to make a new page of CNC Glossary words. So if you have definitions of words please mail them to me @ [email protected] I will add the words to the page and provide a new link.
    May 2005
    173
    Quote Originally Posted by CNCadmin
    2d versus 3d versus 2-1/2d
    Jun 2004
    450
    2d = a part is cut at the same Z depth at all times. Think of a mouse pad, or the outside of a CD. To cut these shapes, Z axis would only need to move to one depth while X and Y are stationary.
    2 1/2D = a part is cut at different Z depths. But when Z moves, X and Y are stationary. Think of a set of stairs. Mill one step, stop X and Y - raise or lower Z, mill next step.
    3D - A part that require constant 3 axis movement. Think of milling the outline of the threads on a baseball. X, Y and Z will need to constantly be moving together. To my knowledge though, any 3d shape could actually be cut as 2 1/2D.
    I've always thought of it like this. 2d - A (single) step. 2 1/2D a set of stairs. 3D - escalator.
    What about swarf? This term is NEVER used in our shop. I've heard it used to describe chips made by a cutter, solid drops, even a 'swarf machine'. And I always feel akward saying it.
    Dustin B.
    I hear and I forget.
    I see and I remember.
    I do and I understand.
    Jun 2003
    453
    Parametric?
    May 2005
    142
    DRO
    also, I was confised with the difference between mill, router, end mill, etc when I started
    router finally being built!
    y axis done!
    hobbycnc controller done!
    ...mounting nsk rails and thk rail. aligning leadscrews
    Oct 2003
    175
    not complete but here is a start
    - A -
    A-Axis- The axis of circular motion of a machine tool member or slide about the
    X-axis. VAlues along the A-axis are degrees of rotation about the X-axis.
    Absolute System- A numerical control system in which all positional
    dimensions, both input and feedback, are given with reference to a common
    datum point.
    APT Programming- Automatically Programmed Tools. A universal computer
    assisted programing system for multi-axis contouring programming. The original
    NC programming system, developed for AeroSpace, first used in building and
    manufacturing military equiptment.
    Algorithm- A computational method for solving problems. Much like a recipe
    in cooking, or a plan of attack in the military. Developing the algorithm in
    machining is the pre-planning process that creates the orderly procedure for
    machining processes to occur.
    Alphanumeric- A system of code that consists of the characters A-Z and
    numerials 0-9.
    Analog- Pertaining to a system that that uses electrical voltage magnitudes or
    ratios to represent physical axis positions.
    Analyst- A person skilled in the development and definition of techniques to
    solve problems.
    Arc Clockwise- G02- An arc generated by coordinted motion between two
    axes. Curvature of the arc is clockwise with respect to the part and the cartesian
    planes.
    Arc Counterclockwise-G03-An arc generated by coordinted motion between
    two axes. Curvature of the arc is counter-clockwise with respect to the part and
    the cartesian planes.
    ASCII-(American Standard Code for Information Exchange)A data transmission
    code that has been established as an American Standard by the Americam
    Standards Association.
    Auxiliary Function-M Codes-A programming function used in CNC
    machining that controls functions other than axis motion. Tool changing,
    coolant on and off, starting and stopping the spindle, etc.
    Axis- A principal direction along which the relative movements of a tool or
    workpiece occur. Three linear axes, occuring at 90 degree angles from each other,
    named X,Y and Z.
    Axis Inhibit- A feature of an NC unit that enables the operator to withhold
    command information from a machine tool slide.
    Axis Inversion-The reversal of plus and minus values along an axis. Mirror
    imaging is used to make a left-handed part from a right-handed toolpath. When
    axis inversion is used circular interpolation is also reversed.
    - B -
    Backlash-A relative movement between interacting mechanical parts as a
    result of looseness.
    Batch Processing-Technique in which items to be processed must be coded
    and collected into groups prior to processing.
    B-Axis-The axis of circular motion of a machine tool member or slide about the
    Y-Axis.
    Binary Code-Code based on binary numbers expressed as either 1 or 0, true or
    false, on or off.
    BIT-Binary Digit-A binary digit has only two possible states. Eight BITS make
    up one BYTE.
    BCL- Basic Control Language ...EIA/ANSI 494. A CNC controller language.
    This was contributed by Steve Harris For more information on BCL visit
    http://www.ncbsa.org Thanks Steve!
    Block-A single line of NC code is a block, a block represents sufficient
    information to a CNC machine to perform a single line or arc movement.
    Block Delete-A function that permits selected blocks of code to be ignored by
    the control system, at the operators discretion.
    Buffer Storage-A place in which information in a control system or computer
    is stored for use at a later time.
    Bug-A programmed error or oversight, a glitch.
    BYTE-A sequence of eight adjacent binary digits(BITS)
    - C -
    CAD-(Computer Aided Design)The using of computers to assist and develop
    phases of design.
    CAM-(Computer Aided Manufacturing)The use of computers to assist in
    manufacturing.
    Cancel-A command that will discontinue any canned cycles or seguence
    commands.
    Canned Cycle-A preset sequence of events initiated by a single G coded
    command.
    Cartesian Coordinates-A three dimensional system whereby the position of
    a point can be defined with reference to a set of axes at right angles to each other.
    C-Axis-The axis of circular motion of a machine tool member or slide about the
    Z-axis. C-axis values are degrees of rotation about the Z-axis.
    Chip-A single piece of silicon cut from a slice by scribing or breaking. A chip
    can contain one or more circuits.
    Circular Interpolation-The process of generating up to 360 degrees of arc
    using only one block of information as defined by EIA.
    CL Data-Processor output that contains information regarding cutter location.
    CNC-Computerized Numerical Control.
    Command-A signal or series of signals that initiates one step or a series of steps
    in the execution of a program.
    Compile-To generate a machine language program from a computer program
    written in a high level source code.
    Console-The part of a computer system used by the operator for communication
    with the computer system.
    CPU-Central Processing Unit of a computer. The memory and logic area of a
    computer that includes processing and execution of instructions.
    CRT-Cathode Ray Tube-A device that displays alphanumeric data to the
    machine operator.
    Cutter Diameter Compensation-CDC-A system in which the programmed
    toolpath may be altered to compensate for cutter diameter differences.
    Cutter Offset-The distance from the part surface to the axial center of a
    cutter(the radius of the cutter).
    Cutter Path-The path defined by the center of the cutter.
    Cycle-A sequence of operations that is repeated. The time the repetition requires
    is cycle time.
    - D -
    Data-The representation of information in the form of NC Words, sysmbols,
    numbers, letters, characters and/or digits.
    Database-A comprehensive collection of information in a specific format
    applicable to a user's needs.
    Debug-To troubleshoot, detect, locate and remove mistakes from a program.
    Decimal Code-A code system in which each allowable position has ten possible
    states.
    Digit-A single character in any numbering system.
    Digital-Relating data in the form of digits.
    Display-A visual representation of data.
    Downtime-Time during which equipment is inoperable because of faults.
    DNC-Direct Numerical Control-A system in which machine coded programs
    are introduced into the CNC controller from a remote computer.
    Dwell Time-A timed delay of programmed or established duration used in
    specific machining operations.
    - E -
    Edit-To modify the form of data.
    EIA Standard Code-A standard code for positioning, linear motion, and
    contouring control systems proposed by the U.S. EIA Standard RS-244.
    End-Of-Block Character-A character representing the end of a programmed
    block of information.
    End of Program-A miscellaneous function (M02) that represents the
    completion of a programmed cyle.
    End Points-The extremities of a span.
    Executive Program-A set of programming instructions that allows a CNC
    lathe to have the capability to perform lathe functions or a CNC mill to perform
    milling functions. A set of instructions designed to output specific functions.
    - F -
    Feed-A programmed or manually established rate of movement of the cutting
    tool into the workpiece for the required machining operation.
    Feed Rate-F Word-A multi-character code containing the letter F followed by
    digits that determine the machine slide rate of movement.
    Feed Rate Override-A variable manual control function that allows the control
    system to increase or reduce programmed feedrates.
    File-An organized collection of relevent, orderly data.
    Firmware-Programs or controlled instructions that are not changeable by the
    user and that are often held in ROM,Read Only Memory.
    Fixed Block Format-A format where data blocks appear in sequentially arranged
    order.
    Fixed Cycle- A preset sequence of events initiated by a single G coded command.
    Floating Zero-A characteristic of a machine control unit that allows the zero
    reference point to be established at any point of travel along an axis.
    - G -
    Gauge Height-A predetermined Z axis clear plane retraction point along the
    Z-axis to which the cuter retreats allowing safe XY axis travel.
    GIGO-Anacronym for "Garbage In, Garbage Out", when a programmer is
    given garbled inaccurate information (geometry), the BEST that can be expected
    is an inaccurate toolpath. ALWAYS, proof every number given to you from
    any Engineer, if you don't you will be re-programming 75% of the work!
    G Code-Active Preparatory Function-An NC word addressed by the letter G
    and followed by a numeric value, G Codes are flags that when executed by the
    machine control unit, initiate axis motions, plane changes, feedrate changes, etc.
    ***Warning: G Codes have different uses and functions from one
    Machine Tool Builder to another, use caution when
    changing to unfamiliar machines!
    G00-Rapid Travel-Axis motion at maximum speed.-Milling-Turning-
    G01-Linear Interpolation-Straight linear axis motion at a controlled feedrate.
    -Milling-Turning-
    G02-Clockwise circular motion using two axes in a single program block.-
    Milling-Turning-
    G03-Counter-clockwise circular motion using two axes in a single program
    block.-Milling-Turning-
    G04-A dwell, stoppage of axis motion, for a programmed length of time.
    -Milling-Turning-
    G17-X,Y plane selection.-Milling-
    G18-X,Z plane selection.-Milling-
    G19-Y,Z plane selection.-Milling-
    G20-G70-Inch units(G20 or G70 depends on the MTB)-Milling-Turning-
    G21-G71-Metric units(G21or G71depends on the MTB)-Milling-Turning-
    G28-Automatic return to a reference point.-Milling-Turning-
    G29-Automatic return from a reference point.-Milling-Turning-
    G40-Milling-Cancel Cutter Diameter Compensation
    G40-Turning-Cancel Tool Nose Radius Compensation.
    G41-Milling-Cutter Diameter Compensation on, cutter left.
    G41-Turning-Tool Nose Radius Compensation Left
    G42-Milling-Cutter Diameter Compensation on, cutter right.
    G42-Turning-Tool Nose Radius Compensation Right
    G70-Turning-Canned Finishing Cycle
    G71-Turning-Canned Roughing Cycle
    G72-Turning-Canned Facing Cycle
    G74-Turning-Canned Peck Drilling Cycle
    G75-Turning-Canned Grooving Cycle
    G76-Turning-Canned Threading Cycle
    G80-Cancel Canned Cycle.-Milling-
    G81-Canned Drilling Cycle.-Milling-
    G82-Canned Cobore Cycle.-Milling-
    G83-Canned Deep Hole Drilling Cycle.-Milling-
    G90-Absolute Positioning.-Milling-
    G91-Incremental Positioning.-Milling-
    G92-Repositioning or re-setting the origin point.-Milling-
    G98-Milling-The initial machine reference positioning system.(Machine
    Reference Zero)
    G98-Turning-Linear Feedrate Per Time.
    G99-Milling-Cancel G92 position set.(PaArt Reference Zero)
    G99-Turning-Feedrate Per Revolution
    H -
    Hard Copy-A readable output of data on paper.
    Hardware-The components that make up a computer or control system.
    Hard-Wired-Having logic circuits interconnected on a backplane to give a
    fixed pattern of events.
    - I -
    Incremental Dimensioning-A method of expressing a dimension with respect
    to the preceding point. NOT a good idea, incremental dimensioning allows
    users to fall into a trap. If a single error in data is entered incorrectly at the
    beginning of a project, ALL points determined afterwards will have that
    amount of error built into them.
    Inhibit-To prevent an action or event.
    Input-Transfer of external data into the control system.
    Interpolation-A function of a control whereby data points are generated
    between given coordinate positions.
    ISO-International Organization of Standardization.
    - J -
    Jig- A fixturing device used most often for drilling operations.
    Jog-A control function that momentarily operates a drive into the machine.
    - K -
    - L -
    Leading Zeros-Redundant zeros to the left of a number.
    Letter Address-Often called NC Words, such as X,Y,Z,F,G,M.
    Linear Interpolation-A control function whereby data points are generated
    between given coordinate positions to allow simultaneous movement one, two
    or more axes of motion in a linear path.
    Loop-Repetitive operations can be programmed in a continuous mode until the
    desired functions have been completed.
    - M -
    Machine Code-Code obeyed by a computer that needs no further translation.
    Machining Center-Machine tools, normally Numerically Controlled, capable
    of automatically repeating many operations such as drilling, reaming, tapping,
    milling, and boring multiple faces on a workpiece.
    Machine Tool-A power driven machine used to form or shape metal and other
    materials.
    Macro-A group of instructions that can be stored and recalled to solve a
    recurring problem.
    Magnetic Tape-A tape made of plastic or mylar that is covered with magnetic
    particles. It stores information by selective polarization of portions of the surface.
    Manual Data Input-MDI-A mode of control that allows the operator to input
    data into the control system, the data input is identical to the data that can be
    input by other means such as tape or DNC.
    Manual Part Programming-The preparation of a manuscript in machione
    control language and format to define a sequence of commands for processing
    by a CNC machine.
    Manuscript-A written or printed copy, in symbolic form, containing the same
    data as that punched on cards or retained in a memory unit.
    Memory-An organized collection of storage elements into which a unit of
    information consisting of a binary digit can be stored and from which can later
    be retreived.
    Mirror Image-The reversal of plus and minus values along an axis. Mirror
    axis inversion is used circular interpolation is also reversed. Use of (INV,X1Y0)
    is a Type II language command.
    Modal-Pertaining to information that is retained by the system until new
    information is obtained that replaces it.
    Module-An interchangeable plug-in item containing components.
    - N -
    N/C-Numerical Control-The technique of controlling a machine or process by
    using command instructions in coded numerical format.
    Null-Pertaining to a zero output from a device.
    - O -
    Offset-A displacement in the axial direction of the tool equal to the difference
    between the actual tool length and the programmed tool length.
    Optional Stop-A miscellaneous function similar to Program Stop(M01) except
    that the control ignores the command unless the operator has previously
    pushed a button to validate the command.
    Output-Data transferred from an internal storage unit to storage or an
    output device.
    Overshoot-The amount by which axis motion exceeds the target value.
    - P -
    Parabola-A plane curve generated by a point moving so that it's distance
    from a fixed second point is equal to it's distance from a fixed line.
    Parabolic Interpolation-Control of a cutter path by interpolation between
    three fixed points, with the assumption that the intermediate points are on
    a parabola.
    - Q -
    (empty)
    - R -
    (empty)
    - S -
    - T -
    (empty)
    - U -
    (empty)
    - V -
    (empty)
    - W -
    (empty)
    - X -
    (empty)
    - Y -
    (empty)
    - Z -
    (empty)
    (empty)
    Dec 2006
    17
    Anyone going to do more on this? There are still things I need to learn, after repairing industrial electronics / electrical for the last 15 years.
    Right now I'm looking for the def for "Gantry" -- same as moving table on a mill?
    Thanks!
    Don
    WIDGIT:
    Widgit is a general-purpose term, or placeholder name, for any unspecified device, including those that have not yet been invented. It is commonly used in textbook and other examples where the identity of the product or function is irrelevant and could be distracting: students may be asked to design a business plan for the XYZ Widgit Company. Compare Acme.
    Just thought I'd add my 2 cents
    Dec 2006
    17
    Not to be too picky, but I always saw it spelled "widget" (I just started using the Yahoo! Widget engine, lots of cool ways to junk up your desktop and gum up your computer's operations!).
    Please don't take this as offensive. The English language is one of my favorite play-toys, and I feel very sorry for anyone who needs to learn it as an adult -- it is so very hard for little children who don't know anything else -- I am having a blast learning Spanish, with its (not it's) relatively small list of irregular verbs.
    Don
    Yes, you're correct, i just fudged it to match my handle!:devious:
    Dec 2006
    17
    What kinds of widgits do you master / make?
    Don
    Quote Originally Posted by Docter Don View Post
    Don
    http://www.cnczone.com/forums/showthread.php?t=21872
    Jan 2007
    11
    Question
    Quote Originally Posted by CNCadmin View Post
    I'm going to make a new page of CNC Glossary words <>
    Hi CNCadmin -- Did the glossary ever happen? I am desperate to read through it all whilst I work on funding for funding my Tormach.
    If so, please post the link - if not, will it happen?
    Thanks!!!
    ~ TheShooter
    May 2005
    1662
    Quote Originally Posted by theshooter View Post
    It doesn't show up in a search. Maybe it's time to revisit this idea?
    Silly contribution:
    cycle start monkey - Loads parts and knows the green button from the red button. Cnc knowledge ends there.
    The last shop I worked at used this term. Is it an industry standard or did we coin a new phrase? The inspiration for my user name btw.
    Nov 2005
    1468
    Driving Error: When you push the Z jog button, but forget you're in Rapid Traverse so instead of the tool jogging in a few microns it rams into your part at six inches per minute while the part is rotating at 6000 RPM, usualy accompanied by pysiologial symptoms such as rapid heart beat, sweating and an uncontrolable urge to profane. Ouch.
    Oct 2007
    20
    NURBS - non uniform rational b-line spline.... or something like that
    Jan 2007
    355
    Gravity Clamps - A method of workholding in which the force of gravity alone is used to hold the workpiece for machining. This is the preferred method of novice machinists. Other workholding options, such as existing hydraulic or manual clamps, provide more holding force and should not be dismissed.
    Diplomacy is the art of saying "Nice doggie" until you can find a rock. - Will Rogers
    Feb 2008
    41
    Quote Originally Posted by cyclestart View Post
    Silly contribution:
    Also known as Button Pusher.
  1. Using your CNC Mill as a CNC Lathe
    By lstool in forum Knee Vertical Mills
    Last Post: 06-12-2017, 02:29 PM
  2. Making money with CNC
    By Johnuk in forum Community Club House
    Last Post: 12-13-2009, 05:46 PM
  3. Beginners CNC Advice
    By UKRobotics in forum Uncategorised MetalWorking Machines
    Last Post: 10-08-2009, 05:10 PM
  4. The start of a big CNC project...
    Last Post: 09-30-2004, 11:34 PM
  5. CNC Glossary
    By cncadmin in forum Community Club House
    Last Post: 07-12-2003, 09:13 PM
