Hello
Thank you for entering
I was wondering if there in any other way or quicker way with Hypermill to verify if all you finish tool-paths are cleaning the job properly without leaving any area without being machined.
I use the Internal machine simulation, and every time I need to wait for all the programs to run completely and then I check the machined model, this takes long time and if it is a big job you even struggle to rotate/move the model to see if it has been machined correctly.
any suggestion according this matter will be very appreciated
Thank you in advance for your support
