I seem to be either not understanding how to make the surface better through mesh settings or I have something set incorrectly you can see in the picture I have random inaccuracies along the surface as well as all the paths are faceted if you look at bottom edge you can see it .... for reference the grid in the back ground is 1mm and each facet is .3mm long
I have tried all kinds of settings in rhino mesh as well as absolute tolerance of .001 mm in madcam
It seems to me that no matter what settings I use the render gets no better
I assume the render shows mesh quality
gregore
