Hello,
just finished my avid Benchtop Pro 2x2 and I have a question concerning the T slot bed. Moving the probe all along the bed, i have very big Highs and Lows. ( +0.10mm and -0.03mm) wich makes 0.13mm in total along the bed.
I wonder if:
- Is it normal to have such big numbers?
- Does someone have already tried to surface the bed to get better flatness.
- the fact that the extrusions are round at the top, it seems non practical to use the table as it is. Does someone had success using the router straight on the aluminum T slot extrusion.
- Are you all using spoil board, I would like to avoid mdf, did someone already tried aluminum or acetal spoil board.
- In the case of spoil board, what is your setup, threaded holes? mdf planks in between T slots ?
Hugues P
