Originally Posted by
QuinnSjoblom
Thanks Gerry, I was hoping you would chime in on the mach3 side of this problem. I'm not familiar with modbus so I wasn't sure exactly what the situation was there with other vfds. That's good news that mach3 will control any vfd with modbus capability, but here's the question, will it behave the same way as my current setup does with the HY plugin? Currently I can configure mach3 to control a step/dir spindle (my servo driven turning spindle) and mach3 will still send commands through the plugin to control my HY plugin simultaneously. For example If I command an sxxx m3, it will send out step/dir pulses through the specified port/pin for spindle, AND it will send the same command to my vfd at the same time. With a regular modbus spindle setup (not HY plugin), will I be able to also configure mach3 as step/dir spindle and get the same behavior like before?
