Hello
Thanks OkumaWiz for help.
I'm sorry I didn't answer for a while because I was on vacation.
YES the spindel rotation problem is solved.Like you said it was a optional parameter Nr.34 bit 2 which was the problem.Now works fine.Thanks to You.
The controller on the machine is OSP 7000L.
When I press the turret rotate button I don’t hear anythingt that the turret is unclampt and yes i have problem indexing on both turrets.
If anyone has a similar machine I would ask if he can send backup parameters of his machine to this post that i be able to compare with ours.
Best regards
