588,676 active members*
6,760 visitors online*
Page 1 of 3 123
Results 1 to 20 of 44
    Jan 2020
    34
    about setup KFLOP+KANALOG
    this is my first job. does anyone have an example c program for press brake with KFLOP + KANALOG board?
    I have connected the KFLOP + KANALOG to the press brake machine. and I've tested the input output using GCODE in Kmotion.exe and everything is correct as the original. only for DACS 0 to DACS 3 I have not tested it. I use DACS 0 plan for Analog Amplifier (Axis Y1), DACS 1 for Analog Amplifier (Axis Y2), DACS 2 for Pressure and DACS 3 for Crowning.
    Yesterday I tried moving the axis but it didn't move, I saw the voltage in the Analog Status (Kmotion) for the DACs only came out 0.48 volts.
    my first question, can I test the c program in Kmotion and connect the KFLOP + KANALOG to the Analog Amplifier Press brake machine? to drive hydraulic.
    second, can the hydraulics move, if the Analog Amplifier for Pressure and Crowning has no voltage? because I see my normal machine, Analog Amplifier Presure and Crowning have a voltage of 5 volts. and if RAM goes down, Analog Amplifier (Axis Y1 and Y2) -5 volts, if it rises +5 volts.
    May 2006
    4060
    Re: about setup KFLOP+KANALOG
    Don't run GCode until after you have the Axes configured, tested, and tuned.
    I assume Y1 and Y2 are the hydraulic cylinders to move the Press up and down? I understand crowning is used to compensate for flex of the table? I wouldn't think that would be needed for basic operation. What is "Pressure" used for?
    To get more DAC voltage increase the max limits on the Step Response Screen. For example with max error of 200 and P Gain of 0.4 the max output voltage will be:
    200 x 0.4 = 80 DAC counts
    80 / 2048 x 10V = 0.4V
    Don't create a C Program until after you have the machine configured and tested using the Step Response Screen
    Its up to you to understand how your machine works. To command DAC voltages to DACs not used by an Axis you can use DAC Commands on the Console Screen. ie DAC2=1024 DAC3=1024 to apply 5V
    TK
    http://dynomotion.com
    Jan 2020
    34
    that's right sir
    If RAM is not able to press / bend the workpiece, valve proportional for pressure will be increased to increase the pressure automatically.
    Step Response for the / ch axis is executed independently, can it be run together? so I can set it to sync.
    I'm afraid the RAM will skew, if I test one by one.
    is there a solution for that sir?
    if so, I will still try one by one, but not too far away. I hope I succeed.
    May 2006
    4060
    If RAM is not able to press / bend the workpiece, valve proportional for pressure will be increased to increase the pressure.
    I don't understand. Wouldn't the Y1 Y2 valves do this?
    Please read this.
    Yes make very small moves first.
    TK
    Jan 2020
    34
    recently I tried moving the CH1 axis, and it managed to go up. but to move down, still can't. and a new problem, the axis can't hold the position, always moving down by about 1mm / minute.
    when moving up, the analog Amplifier needs +8 volts, below it can not (possibly due to the influence of gravity and load).
    after that I have not tried again to move down, I want to find more information, so as not to take a wrong step.
    when moving up, I see Step Response Command and position are not the same, and the output cannot adjust the position / command, only straight (as if there is no Acceleration or Deceleration).
    below is the tuning that i did:
    P = 1, I = 0, D = 0
    Max limits:
    output = 1024, integrator = 100, error = 700
    motion profile:
    V = 400000
    A = 40000
    J = 40000
    Dead band range = 1, dead band gain = 1
    My Questions 1. Where is my tuning error?
    Question 2. How to rate / assign values for V, A and J?
    is there a formula for that?
    Question 3. Do I have to configure the DAC for valve pressure so that it is compatible with the linear encoder? because earlier I only gave a fixed voltage of +8 volts from the DAC.
    May 2006
    4060
    Please answer the question in my last post. It is important. Before trying to tune the system we should understand how each part of the machine works.
    If the axis is servoing and tuned properly it should hold position.
    Which amplifier? Seems wrong to need 80% of full scale to move at all. Are you referring to both of the hydraulic valves? Or Pressure DAC?
    P = 1, I = 0, D = 0
    Max limits:
    Max error of 700 and PGain 1 would limit the output to 700 DAC counts (3.4V). I thought you said it took 8V to move? Post a plot of Command, Position, and Output.
    V = Velocity in encoder counts/sec A = Acceleration in encoder counts/sec^2 J = Jerk in encoder counts/sec^3
    What is the resolution of your encoder?
    You will need to research how your machine is supposed to work. Or run experiments to figure it out.
    TK
    Jan 2020
    34
    yes, Y1 Y2 valve which performs rising and falling. direction up and down direction.
    and a pressure amplifier to adjust the pressure.
    Pressure DAC (+8 volt).
    hydraulic valves(Y1= 3.4 volt ).
    i did tuning only for axis (CH1) and DAC (3,4 volts).
    while +8 volts for DAC pressure, I gave it via the kmotion.exe console
    I don't know how to add pictures. how do i add a picture on the forum?
    this data from my linear encoder:
    Measuring standard = 20 um
    Accuracy grade = ± 10 ?m (± 0.0004 in.)
    model = LS623 HEIDENHAIN
    Max. traversing speed = 60 m/min (2362 ipm)
    Vibration(55 to 2 000 Hz) = 30 m/s2(IEC 60 068-2-6)
    Shock(11 ms) = 200 m/s2(IEC 60 068-2-27)
    i still have doubts about the proportional valve for pressure. Should it be adjusted by a linear encoder or does it have to set its own voltage?
    I have sent the valve diagram and press brake oil flow in the email.
    May 2006
    4060
    I believe Y1 and Y2 are +/-10V analog proportional valves. So I would expect them to control pressure. Please explain what the Pressure control is needed for.
    click on the insert image button and upload the file.
    The encoder probably has a 20um pitch scale. But the resolution is probably something else. Please determine what the resolution is.
    Good question. You will need to determine how it is supposed to be used.
    Please post all information here.
    TK
    Jan 2020
    34
    51/5000
    this is a diagram of my engine's valve and oil flow.
    Jan 2020
    34
    how to test with 2 hydraulics?, because if only one, it will be skewed. and a little dangerous.
    Jan 2020
    34
    can the Configuration & Flash output 2 DACs?
    May 2006
    4060
    Configure as Master/Slave Axes. See also here.
    TK
    Jan 2020
    34
    Quote Originally Posted by TomKerekes View Post
    100/mm
    just now, I can already test 2 hydraulics. but the plot results are not perfect. the value for V A J is still I'm looking for. as well as P I D. I need information to determine it.
    Jan 2020
    34
    this is data from my linear encoder LS 623 HEIDENHAIN
    Jan 2020
    34
    this is a plot image, what's wrong with this.
    ram can hold the position, but ram Y1 with Y2 difference of 4mm.
    I made Y1 the master. Please help.
    what should i change?
    Jan 2020
    34
    please teach me how to set V, A and J.
    May 2006
    4060
    Can you see that the Position (red) is not changing?
    Can you see how much Output (green) is going to the Amplifier?
    Can you see the plot time is only showing us the first 0.1 seconds? Change to 3 seconds.
    Remove the Deadband it only causes confusion (Set Range to 0 Gain 1)
    Please explain your understanding of Velocity.
    Please don't take photos of the screen. Use Alt-Print Screen to copy to clipboard, paste into paint.exe, save as an *.png file.
    TK
    Jan 2020
    34
    speed to move towards the target. if wrong please correct.
    i try :
    P= 1.6 I=0 D=0
    output=2047
    integral=200
    error=100000
    V=400000
    A=40000
    J=4000000
    step 3 time,sec and size 90
    but the position still doesn't move up or down. what to arrange, in order to move.
    what happens if I give A less?
    and what happens if V, I give it a smaller value?
    maybe if it still can't move, I will change the input channel to ADC and output to DAC.
    I want to see if it can move.
    can i do that at kmotion.exe?
    May 2006
    4060
    yes, maximum speed
    size 90
    This is a very small quick move of less than a mm.
    A=Acceleration=rate of change of velocity
    No the input mode for should be Encoder.
    Make a bigger slower move. Post Screen Captures of the Step Response, Configuration, and Filters Screens.
    TK
    Jan 2020
    34
    This is the image for the CH0 (slave) and CH1 (master) configuration.
    Please correct me, if I am wrong.
Page 1 of 3 123
  1. Kflop/Kanalog/Mach3 setup motor how to ?
    By k-linkz in forum Dynomotion/Kflop/Kanalog
    Last Post: 12-27-2017, 03:33 PM
  2. kanalog+kflop+amplifier setup question
    Last Post: 11-23-2017, 07:10 PM
  3. KFLOP/Kanalog set up
    By cjsamples in forum Dynomotion/Kflop/Kanalog
    Last Post: 10-30-2015, 12:58 AM
  4. KFlop Kanalog and DMM
    By slonold in forum Dynomotion/Kflop/Kanalog
    Last Post: 12-26-2014, 10:54 PM
  5. Kflop - Kanalog setup guide.
    Last Post: 07-27-2013, 05:42 PM
