588,150 active members*
5,574 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Need help with PC Parameters on a Fanuc 6M
Page 2 of 3 123
Results 21 to 40 of 55
  1. #21
    Jul 2006
    131
    hi I have a okuma howa 3VA whit fanuc 10M and i lost the parameters
    by replace the batery, i have the parameters by tape but i don´t know
    how to charge it. does any one can help me !!!!!!!!!!
    tanks a lot
  2. #22
    Jun 2006
    9
    fanuc-6mb parameter
    I have fanuc 6mb parameters and maintenance manual.
    If you want to get
    Give me([email protected]) your e-mail address
    Good luck
    Quote Originally Posted by drthilina View Post
    Yes I downloaded the Zip that you've posted before.
    Those are having just the options, not the NC parameters for that CNC (Centrum 1000) do have that CNC's parameter set. the once containing some values in 0-9999 addresses!!!? :cheers:
    this is all happening because, I dont know hoe to put the parameters using the tape reader, nor i dont exactly know the serviceble condition of the tape reader unit.
    any how if you know how to, insert the parameters using the tape reader, pls let me know. :cheers:
  3. #23
    Dec 2006
    51
    For a Nominal Fee, I can convert your Paper Tape to a PC friendly File and also supply a print out of the data.
    PM me for more info.
  4. #24
    Dec 2006
    51
    Versa
    On the standard 6M control there was ONE set of Offsets 01 to 99
    The same offset data was used for Both, tool Lengths, and tool Radius
    If your tool changer has 20 tools, use offset numbers 01 to 20 for the Lenghts, and offset numbers 31 to 50 for the tool radius.
    add 30 to the tool number for the radius offsets
    To enter a value in the offset, you place the cursor on the offset number,
    Enter a P then the value you want to enter. press input
    In your program you use G43 H01 look up the value in offset 01
    G41 or G42 D31 look up the value in offset 31
  5. #25
    Jul 2006
    131
    manual 6m
    Hi I´m Guillermo Meneses from Mexico , I have a problem whit my
    cnc OKUMA HOWA 3VA it have a control FANUC 10M and i lost
    the parameter by error at replace the batery, i apreciate a lot that
    you send me a copy of your manual to FANUC 6M to try setup up
    again my 10M
    my email [email protected]
    thanks a lot
    Guillermo Meneses
    Quote Originally Posted by Hwangbogeun View Post
    If you want to get
    Good luck
  6. #26
    Jul 2006
    131
    10m parameters
    what can i need to do that, and how can i download the parameter to my
    FANUC 10M
    [email protected]
    Quote Originally Posted by vpcnc View Post
  7. #27
    Mar 2007
    Fanuc 6MB
    Hi I have an old Mazak H20 Machine with a Fanuc 6MB control,
    I had problems and lost all the parameters, I just reload them but know when I try to send the Y axe Home itruns like crazy to the limit switch.
    Is there a parameter to control that?
  8. #28
    Jan 2007
    48
    How many axis have your machine i have parameter for sofia machining center 5 axis and makino horizontal 3 axis, and mazac horizontal 4 axis.
  9. #29
    Jun 2007
    14
    Pls help me,
    I need Fanuc 6M modelB PC parameter and Mainternance Pls send me by email: [email protected]
  10. #30
    Jul 2006
    131
    download parameters
    How can i download the parameters to my cnc OKUMA HOWA 3VA
    i don´t know how to do that
    i have a parameter tape
    the reader is like this
  11. #31
    Jun 2007
    119
    Can anyone tell me where I can get the parameters for fanuc O-TD all. Help.
    Email [email protected]
  12. #32
    Jun 2007
    6
    Anyone can help me change character display in my Fanuc 6M?
    All characters are in Japanese, and I want to convert it into English.
    Please, anyone knows the parameter # for the convertion of language with this system? Please, help me....
  13. #33
    May 2005
    7
    Hello!
    I have a John Ford machine Fanuc 0M command, and is working well. Would you please tell me how to backup all the important data (parameters, macro variables, offsets...) so that in case of a memory reset, to be able to do a data restauration.
    Thank you!
  14. #34
    Mar 2007
    156
    Quote Originally Posted by Dan Fritz View Post
    You said that your paper tape reader was not working. Did you check the SETTING page for the bit marked "INPUT DEVICE 2" ?. If that bit is a "1" then the serial port tries to read when you press the READ button. If this bit is set to "0", then the paper tape reader starts instead. Be sure this bit is set to "0" or your tape reader wont' work.
    I am in a similar situation in that I need to read parameters from my tape. My SETTING page has INPUT DEVICE 2 = 1, and I need to change it to 0 as you described.
    However, I can't figure out how to change it! I move the cursor over to the proper line, press 0 and INPUT, but nothing happens. I read somewhere that I need to be in MDI mode to do this, but I am unable to get into MDI mode because it requires that my axes are zeroed, but my Z axis won't move (that's why I'm trying to reload the parameters in the first place).
    Does anyone know how to change the INPUT DEVICE settings?
  15. #35
    Sep 2005
    767
    You must be in MDI mode, and the memory protect key switch must be off. Display the SETTING page and cursur to the INPUT DEVICE 2 bit. Then, press the letter "P", then press INPUT. That should do it!
  16. #36
    Mar 2007
    156
    Thanks Dan for the super quick reply!
    I will try that, but right now I can't get into MDI mode. The machine is a Wiedemann Centrum 1000. When I press the MDI button, I get an alarm message saying ZERO NOT SET. This is because I am unable to zero the T axis.
    Is there a workaround to get into MDI mode without zeroing the axes?
  17. #37
    Jun 2007
    14
    Is your machine punch press. Push emergency then do it
    Grass is always greener on the other side of the hill
  18. #38
    Mar 2007
    156
    Thanks - I have tried two different ways to put the machine into emergency mode, however it still will not go into MDI mode.
    I once managed to trick the machine into thinking that the turret was zeroed, but I cannot seem to duplicate it.
    Any other ideas?
  19. #39
    Jan 2011
    in the back cabinet you will find th OD board on this board you will find the emergency state parameter switch(esp)
    this switch will allow you into MDI mode
  20. #40
    Feb 2011
    Fanuc 6MB Parameters Lost
    Hi All,
    We have a Bridgeport 320H with a Fanuc 6MB controller. We have lost our parameters & are unable to run the machine.
    Could you please help us in getting the parameters. You may email us at [email protected]
    Thank in advance.. Regards
Page 2 of 3 123
  1. Parameters FANUC O-L
    By nsdjole in forum Fanuc
    Last Post: 04-25-2022, 05:29 PM
  2. Replies: 3
    Last Post: 10-22-2020, 09:20 PM
  3. fanuc 11t parameters
    By aguilar in forum Community Club House
    Last Post: 06-26-2013, 07:40 PM
  4. Parameters for YAM CK-5, Fanuc 10T
    By gisab in forum MetalWork Discussion
    Last Post: 12-07-2009, 09:39 AM
  5. Fanuc 0T G83, G84 parameters
    By davisboys in forum Fanuc
    Last Post: 03-18-2007, 05:29 AM
