587,625 active members*
3,134 visitors online*
Results 1 to 16 of 16
    Dec 2006
    7
    Bridgeport EZ-TRAK
    Hello...I have a circa 1988 bridgeport EZ-trak 2 axis knee mill. Has any had any sucess linking this older control to any cad/cam softwares out there. As it is now i cannot even save programs. Was trying trial version of Multi-DNC software but could not get the control to communicate with the PC. Thanks in advance for any suggestions.
    Oct 2006
    586
    what cable are you using on your multi
    individual who perceives a solution and is willing to take command. Very often, that individual is crazy.
    Dec 2006
    7
    bridgeport ez-trak
    I tried both a null modem and staight thru 25 to 9 pin cable. Does anyone know if the EZ-TRAK RS232 port is custom for machine?
    Oct 2006
    586
    on the pc side try your 9 pin wiring 2,3 & 7 on the machine side 2 & 3 then jump 4 & 5 then 7 then jump 6 & 8 then jump from 8 to 20 that is for fanuc and i think the EZ is the same
    Oct 2006
    586
    dont jump 4,5 &7 on the machine side 3,2,& 7 are single sorry just want to be clear
    Dec 2006
    7
    bridgeport ez-trak
    Thanks Jackson...Our computer guru is going to make up a cable. I'll let you know how we make out.
    Oct 2006
    586
    good deal
    Apr 2005
    1268
    Geno;
    Do you by chance have any documentation on the installation of the motor mounts and the z-axis drive for the EZ track. I purchased the mechanical system only for installation on my bridgeport and cannot locate any pictures or documentation of the installation. Any help will be appreciated.
    Thx.
    Bill
    billyjack
    Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>)
    Dec 2006
    7
    Brideport EZ-TRAK
    Bill, The EZ-Trak I'm using is only a 2 Axis machine. The Z has a glass scale but is strictly manual.
    Oct 2006
    586
    Hey Geno,
    have you got your EZ track going yet
    Aug 2005
    1622
    Geno,
    Follow this thread. I have the same control as you, but I didn't know these were made before 1990.
    Older LED Display EZ-Trak RS-232 communications
    Mine works great with this setup.
    DC
    Dec 2006
    7
    Brideport EZ-Trak
    Hey DC (or others) would you mind sharing exactly what your set up is? I'm trying to get the basic EZ-Trak to communicate with a software called multi-DNC. We're still at the trial period stage and can use something else if necessary.
    Aug 2005
    1622
    Geno,
    These older controls will not DNC at all. You can transfer small programs via EZ-Link, but that is about it. I have had to break larger programs into sub-sections. I think the limit was 100 lines, but I cannot recall off hand.
    As per the previous thread link is my exact setup. The cable schematic as posted there can be mocked up with soldered connectors and housing shells. The EZ-Link terminal program I use makes the PC a basic server so all transfer(send/receive) is done at the machine control. The format of the program is critical otherwise the control will display "No Link". The program name must be named, called or sent as a number otherwise "No Link". Writing programs on the control and sending them to the PC will produce the proper format to reload them to the control. Post processed programs via a cam system must use the proper format and language syntax also or "No Link" will result. Same conditions apply for buad rate, parity and stop bits.
    Unfortunatley, we are forced to adapt to these contraints to make it communicate.
    DC
    Dec 2006
    7
    bridgeport ez-trak
    Thank you DC. I'll can hope to do to improvew this control is store programs...which is more than I can do now. No point in beating a dead horse...right...HaHa
    Nov 2004
    3028
    The 1988 version control was made by Southwestern. The newer versions go under the name of PROTO TRAK. It did do RS232 but did not DNC.
    George
    Dec 2006
    7
    Brideport EZ-Trak
    Thats right the control is a Soutrhwestern and it will not DNC. But with information from this group I was able to get the pin out info and the EZ-FILE software. I now can at least save programs.
