Hello
i'm new here in the forum bought a used China CNC6040 from the vendor: "SXCNC" milling machine with 4 axis.
In this the mainboard of the type JP-3163B is installed with an additional driver module for the 4 axis, which is connected to the mainboard
connected.
The board has a pure parallel connection
I can only set my frequency inverter manually at the moment.
Now I wanted to do the wiring directly to do this with the CNC program.
The frequency inverter is of the type: MK100-2S1.5G-DK.
Here ins this forum I found the following instructions for the frequency converter which are also stored there with this link:
https://1drv.ms/b/s!AlWEvfzVs336oREF9zNq6qcxH5kF
I have photographed the connection terminals that I have on the frequency inverter on my system.
In addition, I found the following circuit diagram of the mainboard JP-3163B on the Internet.
It shows the newer version I only have the one with a parallel port connection.
Can someone tell me how to wire this up? Please look at my pictures.
Does anyone have the same CNC milling machine where these functions are already wired.
I only found a discussion in a russian forum for the frequency inverter MK100-2S1.5G-DK. However, everything is written in Russian.
So I couldn't ask there either.
Regards Raini
