587,657 active members*
3,554 visitors online*
IndustryArena Forum > MetalWorking Machines > EMCO CNC Machines > EMCO Lathe > Retrofit of an EMCO 120 CNC lathe
Page 4 of 4 234
Results 61 to 70 of 70
  1. #61
    Jul 2009
    152
    Re: Retrofit of an EMCO 120 CNC lathe
    Yes, that seams to be what is happening. I probably not helping ether by not really knowing what I'm doing.
  2. #62
    Oct 2004
    832
    This seems to be the wiring info for your turret, if it is then maybe send the link to Mike and see if he can tell you how to wire and he should also be able to write the toolchange macro to suit. I actually think the macro the SZGH control comes with will be very similar.
    Diagram of NC Turret
  3. #63
    Jul 2009
    152
    Thank you for that, the one they email me the other day was nothing like that.
  4. #64
    Oct 2004
    832
    Quote Originally Posted by Rick_B View Post
    It is just one I got from their site so maybe it is not the correct one.
  5. #65
    Jul 2009
    152
    Hood,
    I check it against the board I have on the lathe and the pin layout looks the same. Looking at the one CNC-makers sent me, I think its more connection options.
  6. #66
    Jul 2009
    152
    Hood,
    Question. With the CN5 driver plug, I have wired it the way Mike said but when I plug it in to the controller and the servo drives the controller will not power up, but it powers up no problems with it unpluged. I have checked the cable and I have had someone else also check it and it is as per the diagram from SZGH. Any suggestion?
  7. #67
    Feb 2018
    11
    Hi Mukanico,i have Emco Compact 6 CNC with old TM02 I want to replace whit SZGH CNC990TDb 2.Can you please email me so I can ask you a few things.I see you have a good experience whit this SZGH.
    Thanks in advance Andrej. email is: [email protected]
  8. #68
    Jul 2009
    152
    Well my install of the SZGH CNC1000TDb on my lathe is chugging along and I'm down to the last few things. It probbely would have easier if had knowen a bit more about electronics,
    After getting over the language diffrence (some times) Mike at SZGH has been a real help. Hood's write up's and video's have also helped to. I will put up some pictures when finished.
  9. #69
    Jul 2009
    152
    Hood,
    Sorry, my pm's are not working for some reason.
  10. #70
    Apr 2019
    5
    Retrofitting a Emco Compact 6 CNC and trying to figure out the tool change macro for it.
    Any pointers setting up the toolchange using original grey code optos and 990Tdb?
    Whos this Mike fellow you keep mentioning in SZGH? how to contact him?
    I have only contacted some sales person, but no technical advice as of yet.
Page 4 of 4 234
  1. Emco retrofit
    By Eatonbrayer in forum PlanetCNC
    Last Post: 01-17-2019, 03:42 PM
  2. Emco PC Mill 50 Retrofit.
    By propellanttech in forum EMCO Mills
    Last Post: 09-24-2018, 01:10 AM
  3. Emco Unimat lathe CNC retrofit
    By ZeroBacklash in forum Benchtop Machines
    Last Post: 09-03-2018, 03:04 PM
  4. Emco Compact 5 Retrofit
    By Daniel.y in forum EMCO Lathe
    Last Post: 01-14-2015, 12:53 AM
  5. EMCO CNC5 Retrofit...
    By oldslotgeek in forum Mini Lathe
    Last Post: 12-31-2007, 01:52 PM
