587,303 active members*
3,313 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Help required...Surfaces
Results 1 to 3 of 3
    Apr 2006
    29
    Hi fellas
    Avid fan of these forums and just learning the 3d part of mastercam,
    I have hopefully managed to draw a 3d part and surface it and attach it for any of you to help me with it.
    I need to machine the surfaces...can anyone help me?
    Attached Files Attached Files
    Jun 2005
    305
    First thing you need to do is fill any "holes" with a surface.
    Use Create, Surface, Trim Extended, Flat Boundry to create a surface that fills the center "hole".
    Your tool will try to machine ANY "holes" that you would see from the spindle axis (Z).
    There are many different approaches to do what you want.
    Attached is a VERY SIMPLE example.
    Please, do NOT try to machine what I sent.
    ObrienDave. MasterCam since V6. Gcode since 1983.
    The nose you punch today may belong to the butt you have to kiss tomorrow.
    Apr 2006
    29
    Good Onya Mate
    G'day Dave,
    Many thanks for taking the time to answer,your solution was spot on!
    I had finished the part a day earlier than your answer....by drawing the bloody toolpath all around it (about 2 hours)
    So you have sorted out that one for me...thank's again...till next time
