Originally Posted by
ninefinger
Your power supply will has 2 outputs at ~72VDC each, look at the wiring diagram that came with it. Each output has a terminal block for convenience so you can easily connect direct from those terminals to your stepper drivers, and put a fuse inline. Also - those automotive fuses are not rated for 70VDC, if you do blow one up it may cause a different fault (fire!) that is as bad or worse than what you were trying to prevent in the first place. Use a simple 1/4" ACG fuse holders (available as inline, panel mount or stand alone bolt down) and then you can select the appropriate fuse for the drives
Also, why do you need handwheels on a cnc machine - especially handwheels that won't have graduations for travel?
