Re: Fixed Bridge Mill - Small footprint, High rigidity
Originally Posted by
routalot
A couple of things come to mind.First of all if the Y axis is the moving table and has 1 metre of travel-you need 2 metres of space for it.Second,while it looks substantial,I would give some thought to reversing the architecture of the side supports.That way you could attach a brace from the corner of the under table cross beam to the top of the upright for better triangulation.
You don't need 2m for 1m of travel. It depends on your bearing spacing.
You won't want the bearings right at the corners of a big table - that would result in the biggest unsupported span.
A rough rule of thumb of 1/4 in from the ends works reasonably.
So you end up with bearings spacing ~1/2 of the table length.
So ~1.5m rail length for 1m of travel.
EDIT: My bad. I read your post as needing 2m bearing length when you were talking about space for the machine. You are correct.
