587,302 active members*
3,157 visitors online*
IndustryArena Forum > Mechanical Engineering > Mechanical Calculations/Engineering Design > What dimension/gauge steel tubing do I need for a bed frame?
Results 1 to 2 of 2
    Jan 2021
    Question What dimension/gauge steel tubing do I need for a bed frame?
    I work primarily with wood, but am now just starting to move into welding/metalworking, so forgive the complete lack of knowledge..
    I'm hoping to build as thin of a bed frame as possible to keep as much space below it as I can.
    The dimensions of the bed are 48"x75" with posts only at the corners
    My question is, what would be the best size tubing (either square or rectangular) for the beams spanning the 75", if I'm only supporting them on the ends. (I'd have all of the slats supporting the mattress itself connected to these two beams)
    I'd love to use 11ga 1"x1" as I have easy access to that, but my hunch is that might not be strong enough, though I'm not sure.
    Would 11ga 1-1/2"x1" be much stronger?
    Is there any sense in using angle iron of a larger dimension (2"x2"x1/8") as the beams, with them oriented with their open angle towards the bed, so they don't protrude downward?
    A combination: angle iron on top of a square tube?? (sounds ridiculous but hey who knows, not me)
    And yes I've tried a variety of deflection calculators, but still am having trouble finding definitive answers. I assume acceptable deflection is different in metal than it is in wood, but I'm not sure in which ways.
    Any help is appreciated, thanks!
    Dec 2013
    5716
    Re: What dimension/gauge steel tubing do I need for a bed frame?
    A standard bed frame is normally made from 1 3/8'' x 1/8'' angle. But it is a high carbon alloy steel that is heat treated to about like a spring. The real question is: Why not just buy one? https://hollywoodbed.com/product-cat...ts/bed-frames/
    https://www.amazon.com/s?k=bed+frame&ref=nb_sb_noss_1
    But if you insist on making one, then I would go with the 2'' x 1/8 angle, the extra width to make up for the lack of heat treat.
    Jim Dawson
    Sandy, Oregon, USA
  1. Where to find precision square tubing for frame/gantry rail?
    By maillemaker in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 01-01-2015, 05:23 PM
  2. Aluminum Extrusions, Steel, or Aluminum Tubing which one for CNC frame?
    By dinkyguitar in forum DIY CNC Router Table Machines
    Last Post: 06-14-2012, 02:51 AM
  3. Steel Tubing CNC Router
    By thegimpster in forum DIY CNC Router Table Machines
    Last Post: 05-03-2008, 12:41 PM
  4. diy vmc from rectangular steel tubing ?
    By andy55 in forum Vertical Mill, Lathe Project Log
    Last Post: 01-02-2006, 10:59 PM
  5. Steel square tubing for frame
    By samualt in forum DIY CNC Router Table Machines
    Last Post: 08-20-2005, 02:44 PM
