Hello,
I have a working CNC using mach3 on window XP, everything works perfectly, but I find it hard to go about, I taught maybe I can run widows XP within a newer windows version.
So, I have installed today everything again on a virtual machine using VMware.
It does work, but not as expected. The motor run very slowly and the sound is not right.
When I test the PP using the application inside mach3 folder, it states "excellent connection".
It has nothing to do with the motor tuning, I have calibrated the axis and plaid with "velocity" & "acceleration".
I also found here on the forum that it is recommended to change the motor steps per revolution to 800 (I had 5000), it does turn a little faster, but still not as it should and the noise is not right.
It seems that changing the connection from 25khz to 100khz has no effect.
Any ideas are more than welcome either as a walk around, or a direct fix.
The reason for all this trouble is that I don't wish to have two separate computers, and when I run windows XP I am technically unable to do anything...
Thanks again,
Nir.
