587,303 active members*
3,500 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC "do-it-yourself" > Milli a new composite mill kit
Page 42 of 109 3240414243445292
Results 821 to 840 of 2171
  1. #821
    Jul 2018
    6468
    Re: Milli a new composite mill kit
    Morning All & Lurkers - Today brings the steel fibre investigation to a close. Block 4 has been cut out of the bucket. Its quite solid and there was a lot of paste on its top. At best it has 10% by volume fiber in it, which gets 34 low and 40GPa high in modulus. So I may as well buy grout that has 34GPa out of the bag. So I need to get some ALOX, SiC or Alumina to get to E70+. I shall try to get north next week for some ALOX. I'm tempted to knock back the material spec in Milli to 35GPa and move along.... material development is a tough gig.... Peter
  2. #822
    Jul 2018
    6468
    some info on damping - Peter
    Attached Files Attached Files
  3. #823
    Jul 2018
    6468
    Evening All - Here's a historical lifting gantry machine, been busy finding some SiC and Alumina in china....... Peter
  4. #824
    Jul 2018
    6468
    Evening All - I use Rule of Mixtures a lot thru here so I thought I'd include an example using some moulded plastic. Zytel 35% fibreglass has been around for a long time and has pretty std properties.
    A simple explanation of ROM is if you add a glass of 50C water to a glass of 100C water you get 75deg C water when mixed...
    https://dupont.materialdatacenter.co...35HSL%20BK039B
    Using the attached data and ROM calc shows the strain efficiency of the combination is n=0.85. In my calcs I have always used 0.5 as this is the bottom conservative figure. This is called "translation" ie how does the theory translate to reality... rounded particles don't transfer strain as well as longer fibres do... so round ed (like sand) tend to the 0.5 figure.. I'm getting some ALOX this coming wednesday if I use 0.5 solids ratio (by volume) with CSA I should get E90 (n=0.5 in both). If I use 0.6 solids and epoxy I should get E77 so they are my targets. If I use epoxy its about $17200AUD per m3 and if I use cement its about $11000AUD per m3 so hopefully the grout approach works out...I'm sure I can infuse ALOX I have infused sand before a few times.... Peter
  5. #825
    Nov 2020
    361
    Hey Peter,
    Have you thought about the anchors yet? Options:
    1. thinner mounting plate + (more) thinner anchors (more balanced?)
    2. thicker mounting plate + (less) thicker anchors
  6. #826
    15362
    Yes a nice old planer if you can find one that size it most likely will still do a very good job a lot of machine builders added a milling head
    Mactec54
  7. #827
    Jul 2018
    6468
    Hi Ard - I have two thoughts 1) cast the aluminium blocks in then machine all the required features into those blocks on a large router or VMC 2) cast in pockets then epoxy in anodised blocks then finish machine . I'm leaning towards 2) at the moment.... Sometimes aluminium and concrete don't like each other and the Al corrodes so epoxy is a good barrier. If I use steel I'll zinc plate them prior to in-situ casting or post placement... Doesn't affect the CAD work at the moment. Haven't had luck getting the Alumina I want local but a chinses company is quoting on a suitable spec. Local blasting grit is a bit more cost then it should be but it will be fine for casting test blocks, fingers crossed some may arrive tomorrow. I have made the CSA test blocks into trivets and they are now in my kitchen.... I will need to get some granite sealer they are a bit porous and suck up stains.... real machine parts will be sealed and painted. I'll have to get Gully onto that he's good with paint....
    Using local materials ALOX/EP E90-95 ~$17000AUD per m3 ALOX/CSA E80-85 $11000 AUD per m3...... Plate Alum at $9/kg $24300 AUD per m3 so not bad.... Peter
    CSA CTE 13.7 ALOX 8.1 Alum 21 steel 12 epoxy 45 cast iron 11 units um/m/C
    Yong Ju make big machines. I do like BIG machines....
  8. #828
    Jun 2007
    3891
    thats a planer.
    it only takes force in a single direction in a very controlled manner.
    doesnt really apply much to a multi axis cnc.
  9. #829
    15362
    If you are going to have the machining done outside then go with steel inserts it won't cost any more to have the steel machined vs, aluminum
    Mactec54
  10. #830
    Jul 2018
    6468
    Hi Mactec - Agreed if I contract the machining then st or al does not matter. Once I have a mill I can machine moulds that only have thread inserts vs "blocks". I'd prefer aluminium but will decide once more detail is filled in. Peter
  11. #831
    Jul 2018
    6468
    Hi All - The usual issue with mixing materials is the CTE delta. If I go with the ALOX/EP and I use 60%V alox and 40%EP then the CTE is (0.6*8)+(0.4*45)= 22.8 which is close to AL @ 21 , ST is half that. So aluminium is a good match.. If I use CSA then (0.5x13.7)+(0.5*8) = 10.9 which is closer to steel so the use steel.. Peter
  12. #832
    Sep 2014
    129
    Video from Keith Rucker about a metal planer he is restoring: https://youtu.be/OZWD8PlDwn4
  13. #833
    Jul 2018
    6468
    Evening All - I have 25kg of ALOX being delivered tomorrow so can continue the struggle for the Holy E70!! Peter
  14. #834
    Nov 2020
    361
    Hey Peter,
    Hope you got that alox today.
    https://i.imgur.com/hziPhBl.png
    Inside the spindle box, had to do an extension between the spindle and the cartridge, alternatively I could run it direct drive, but no way to do regular belt drive without compromising the structure of the bridge. I really want the bridge to carry most of the motor weight as close to the middle of it as possible.
    I'm not sure about the extension though, particularly the bearing config https://i.imgur.com/9xzCViQ.png
  15. #835
    Jul 2018
    6468
    Hi All - waiting for ALOx looks like today. In the mean time I've been playing with the laser. Up to getting the CAD/CAM to talk to it. But I pushed two buttons in sequence trying to do something and it "reset" it cleared the memory of the machine!! Bummer. Now I'll have to figure how to set up the machine variables from scratch with no documents. The ARGUS mountain just got a little taller... Peter
  16. #836
    Mar 2020
    180
    yes, and the bridge is between the columns
  17. #837
    Jul 2018
    6468
    Hi All - Been away for a couple of days. ALOX now in stock may do the first test tomorrow.. Peter
  18. #838
    Nov 2020
    361
    Here's a cool picture about UHPC inserts.
  19. #839
    Jul 2018
    6468
    Hi Ard - Thanks Sudholt-Wasemannn have a lot of info about UHPC on their site.. Got home yesterday from a shirt trip and my main computer didn't boot!! Seems it liked the rest so much its staying cold... So its off to the tech tomorrow. Can't use my CAD system so I'm forced to do some ALOX casting.... Peter
  20. #840
    Nov 2020
    361
    Hey good to hear from you, I was wondering whether one of the outback beasts ate you or something...
    Actually that data is direct copy from durcrete, here's the original repository:
    https://durcrete.de/downloads-english/?lang=en
  1. WillMill - HSM Benchtop Composite Mill
    By Williamlii in forum CNC Wood Router Project Log
    Last Post: 05-31-2020, 07:03 AM
  2. Replies: 1
    Last Post: 07-11-2018, 04:14 AM
  3. Composite Mini Benchtop Mill / Router
    By ficklecycler in forum Benchtop Machines
    Last Post: 06-01-2018, 12:22 PM
  4. Looking for some composite routing
    By Locster13 in forum DIY CNC Router Table Machines
    Last Post: 11-02-2006, 05:20 PM
