587,172 active members*
3,201 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > Ok to cut manually via jogging (without G-code)
Results 1 to 2 of 2
    Jun 2008
    36
    Hey all -
    I need to clean up the edges of some 4x8 melamine and I am wondering if there is any reason I could not just run a 1/4 or 1/2" compression bit along the edge to do the job as opposed to creating something in VCarve?
    For that matter, what if I wanted to rip a sheet of plywood in half?
    Also trying to avoid buying a track saw...
    Shawn
    Sep 2017
    40
    Re: Ok to cut manually via jogging (without G-code)
    Certainly! I do it all the time with both wood and aluminum.
  1. Manually entering code to an R2E4 Bridgeport machine.
    By RWhiteoutboard in forum Bridgeport / Hardinge Mills
    Last Post: 08-21-2017, 07:51 PM
  2. ISO CODE MANUALLY INPUT ON 8040M
    By mousongie in forum Fadal
    Last Post: 11-16-2012, 04:42 PM
  3. For those who code G-Code manually would you like these macros?
    By alank2 in forum Mach Wizards, Macros, & Addons
    Last Post: 05-23-2012, 01:24 AM
  4. Programming Mach3 by just jogging the axes manually
    By uplb in forum Mach Software (ArtSoft software)
    Last Post: 11-15-2008, 03:06 AM
  5. code rotary manually
    By daisydog in forum Mastercam
    Last Post: 01-19-2008, 09:20 PM
