588,202 active members*
3,939 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > How do you back up OKUMA OSP control?
Results 1 to 6 of 6
    Oct 2018
    101
    hi guys do you have procedures for backing up a 1999 OKUMA OSPU100L control ? the entire control
    i am trying to do an upgrade on the control but i want to back up EXISTING control in case upgrade failed. thank you so much.
    Mar 2009
    1982
    Re: How do you back up OKUMA OSP control?
    Do you have the set of installation floppies? Should be in the nice blue box each floppie numbered. This set is most important. Once you have it, you need to backup system and user parameters only.
    Oct 2018
    101
    i do have the set
    Quote Originally Posted by Algirdas View Post
    do you need to be on EDIT LOCK on the NC panel / lock switch while doing the back up?
    Mar 2009
    1982
    "Edit Lock" is only to prevent manipulation with files. Never used normally.
    There is way to perform backup in normal edit mode where you can copy files.
    It's possible, that starting with the "install mode" and SW1 you will be presented with the menu containing backup chapter. This requires some preparations: you need to format some floppies ( 8 should be enough ) into OSP format. This way offers uninterrruptable backup process.
    Oct 2018
    101
    What about the floppy disks to back up existing data
    so I initialize the discs on the control and format them but then I go to my computer and I can’t read them again
    I guess the question is How do you back up the control like you can use them again in case of data loss? because if I don’t initialize first I’m not able to use them to back up data
    At the same time I have the same problem with the new software that I want to install I have the files yet I can’t save them on the floppy disks since they were initialized on the control.
    The original Okuma disks in the blue box we talked about ?I can read them on my computer.
    Is it the initializing process that’s wrong?
    I INITIALIZE “FD0:”
    And “1” for 1.44mb ...
    Mar 2009
    1982
    Okuma provides the application to read/ write OSP format disk on a regular PC. Search through this forum, there should be link to it.
    There are PC applications for making the floppy image doesn't matter what the floppy format used. This solution doesn't allow you to open the floppy and to see it's contents.
    You can open floppies on OSP. Okuma system files are well protected, however - you can't transfer them via serial communication from OSP to PC.
    On the other hand, what's the point if you open the special OSP system files?
    You can open and edit the parameter backup files, user created macro, part program and schedule program files easy - these are user created.
  1. okuma osp7000m back up
    By shredder in forum Okuma
    Last Post: 10-29-2023, 07:13 PM
  2. MV-45/40 6M Control, Back up batteries
    By Steve244 in forum Mori Seiki Mills
    Last Post: 06-14-2018, 07:02 PM
  3. Mach3 spindle control/VFD/back gear
    By Johns tool room in forum Mach Mill
    Last Post: 05-12-2014, 07:06 AM
  4. Back up parameter list 3t control
    By david2259 in forum Fanuc
    Last Post: 04-06-2010, 10:41 PM
