My test PC is running on 2.0.0 IF I upgrade then PP crashes the video. This is just a testing platform and the only pc out of the 6 here that will run PP . THe rest crash the video on startup.
(;-) TP
Looking at Mux4 it still will not do the rotary switches properly for the pendant. 4 inputs and 4 switches with each switch selection applying a separate value . The sample pendant code I have uses mux4 and assumes that each switch can select a separate value but that is not how mux4 seems to work.
(;-) TP
You really should be looking at upgrading somehow. There's a BIG, BIG difference between 2.0.0. and 2.7.2.
If I correctly understand what you want to do, you achieve it with a mux4 and two "or2" gates.
From your 4 digital inputs 0, 1, 2 and 3, ignore digital input 0 (believe me!). For the first or2 gate take or2.in0 and or2.in1 from digital inputs 1 and 3, connect or2.out to mux4.sel0. For the second or2 gate take or2.in0 and or2.in1 from inputs 2 and 3, connect or2.out to mux4.sel1.
This will convert your 4 individual inputs into a binary value (disclaimer - analyzed but not tested).
Give it a try.
Step
I had a friend fix the video problem and did some more testing with Mux4 and found out that you cannot do a hand pendant in PP BECAUSE tormach when they added their pendant code created the link to the axis scale and now you cannot access it from hal as it was already assigned to their jog process . EVEN though this machine does not have the control panel . So unless tormach chages their code to only link to the jog scale IF there is a hooked up then we cannot add our own jog pendant. (;-) V2.0.0 did not have this problem.
I would like to test your code idea but I have no idea how to write that code. IF you have a moment to code it I have time to test it here..
(;-) TP
Here we go:
(You will obviously need to change the Mesa pin designations "hm2_[HOSTMOT2](BOARD).0.gpio.02X.in" to be compatible with your interface and pin outs)
Code:# Load the mux4 and two or2's loadrt mux4 names=mux-axis-scale loadrt or2 names=or-mux-in0,or-mux-in1 # Add the components to the servo-thread addf mux-axis-scale servo-thread addf or-mux-in0 servo-thread addf or-mux-in1 servo-thread # Connect the scale inputs 0 to 3 to the or2 inputs: net scale-select-input0 hm2_[HOSTMOT2](BOARD).0.gpio.026.in # No need to connect it anywhere. You could leave this line out. net scale-select-input1 hm2_[HOSTMOT2](BOARD).0.gpio.027.in or-mux-in0.in0 net scale-select-input2 hm2_[HOSTMOT2](BOARD).0.gpio.028.in or-mux-in1.in0 net scale-select-input3 hm2_[HOSTMOT2](BOARD).0.gpio.029.in or-mux-in0.in1 or-mux-in1.in1 # Connect outputs of the or2 components to the mux4: net mux-selection0 or-mux-in0.out mux-axis-scale.sel0 net mux-selection1 or-mux-in1.out mux-axis-scale.sel1 # Set the scale values for the axis multiplexer: setp mux-axis-scale.in0 0.000025 setp mux-axis-scale.in1 0.000250 setp mux-axis-scale.in2 0.002500 setp mux-axis-scale.in3 0.025000 # Connect the mux output to the axis jog scales: net axis-jog-scales mux-axis-scale.out axis.0.jog-scale axis.1.jog-scale axis.2.jog-scale axis.3.jog-scale
I presume you don't expect to integrate a Tormach Console so just comment out the axis.X.jog-scale inputs in the offending hal file:
I tested it on my test machine. PP runs and the axis.X.jog-scale values change according to the selected inputs. I can't however verify whether the jogging actually works.Code:net console-jogscale turbo-console.0.step-select-value #axis.0.jog-scale axis.1.jog-scale axis.2.jog-scale axis.3.jog-scale
Give it a go if you have time.
Step
I have no idea if the inputs are active high or low. I will have to check .
Testing the code as is when I select any switch position the value is always the same it is the last value .025 BUT if I change all the inputs to NOT then selections do work BUT the switch states are backwards true turns it off and false turns it on
(;-) TP
I'm sorry but I don't quite follow your explanation...
If the original code doesn't work as expected try changing the or2 components to xor2. The main hal file already has an xor2 so you'll have to add them to the list there:
Then delete, or better comment out the line:Code:loadrt xor2 names=probe-active-hi-lo,or-mux-in0,or-mux-in1
This should reverse the sense of the inputs.Code:loadrt or2 names=or-mux-in0,or-mux-in1
Step
OK that worked by using the Xor2. Thank you so very much for the help. The pendant jogs extremely smooth just like it should and each step precise. Now I have to work on the FRO and SSO. I still have not figured out how to push the values to the sliders and labels. But at least it is useable now.
Thanks Again for all the help (;-) (;-) TP
Hi Guys I finally received the hand jog pendant and have it all hooked up and running now. It is smooth , precise and responsive. The pendant is a MPG-2 model from CNC4PC.and I used the C22 pendant interface card to plug it into the Mesa 7i80 . Pretty much plug and play for the most part. Peter at Mesa provided a new BIT file to match the pinout of the C22. It comes with a magnetic back and a steel hanger bracket. It also has a nice coiled retractable cable.
I will update after some more testing.
(;-) TP
Sweet!
Has anyone explored the interface to the rather expensive Tormach Console? From a very quick look it appears to connect to PP as a USB HID device.
I thought there was another postI've had quite a good look at it but I don't like HID devices (in general). It certainly would be possible to create a compatible device and have access to all the features of the console and pendant with the exception of Stop and Reset (if I remember correctly). I actually bought a Teensy specifically to have a go when I've nothing else to do (I just can't resist a challenge).
My USB Pendant is based loosely on the Console but doesn't connect as a HID, and as you may have noticed uses a shuttle encoder because I find them FAR easier to use than the large pendant encoder wheels.
Give it a try!
Step
When I talked to Tormach about their pendant they said it used a special board and was not available except with a console. That is why I worked to adapt a jog pendant to my machines. Having the pendant do XYZA jogging and FRO and SSO means I do not need it built into the console. It serves a duel propose remote jog pendant and when stuck to my console it is a mpg and FRO and SSO. AND it did not cost $2000.
Just a thought. (;-) TP
I will have an update soon.
(;-) TP
Tried to make a self-made control panel. It turned out 16 buttons, three turn switches, mpg wheel, hat-switch for quick movement for lathe.On buttons you can visit any buttons in Pathpilot. MPG moves four axes and serves to adjust the speed of movement, changes spindle, processing speed and TD.The program is written for Stm32 Board. Driven through the hidcomp component.
https://youtu.be/ELm5xddZaEE
That looks pretty feature packed :-)
