The answer is "it depends"-you provide no information about the machine that will be used and a cheap 3018 machine from ebay won't be able to run at the same rate as a large industrial machine.Take a look at this page https://www.shopbottools.com/ShopBot...sandSpeeds.pdf .There are others out there if you search for them and they will all give a starting point from which you may decide to experiment in any direction that seems interesting.
