587,790 active members*
3,427 visitors online*
IndustryArena Forum > Hobby Projects > I.C. Engines > Another effort, 2 cylinder inline water cooled
Page 9 of 11 7891011
Results 161 to 180 of 206
  1. #161
    Jul 2006
    887
    I read this whole thread tonight. Simply amazing. I wish I had the software and machining skill to build something like this. I was hoping to see a running machine by the time I hit page 11.... still, simply amazing. I love the idea and would love to do something like this.
    Can I ask this? Why are you not making double the parts? I know there is alot of time involved. But I would have made double the parts. Spare parts....... Or... simply send a whole working engine to someone in OKLAHOMA (OHHH PICK ME!!! PICK ME!!!!) Looks fantastic, i would love to see and hear this thing run on video sometime in the near future. No preassure or anything
  2. #162
    2139
    The project is a large one even at 1X the parts. I took three whole evenings to get my 4 valves and seats made. Doubling up the engine could make it overwhelming.
    Eric
    I wish it wouldn't crash.
  3. #163
    Jul 2006
    887
    but if you doubled up on the parts, then I could have one..... see how that works?!?!?!?!?! very nice work, I hope you continue the progress on this.
  4. #164
    Dec 2006
    603
    Quote Originally Posted by balsaman View Post
    Eric
    Try 16!!
  5. #165
    Jul 2006
    887
    steve, just from a machined part side of things, that is just beautiful. I wish I had the skill.
    Hell i would love to find something really simple to machine on my little mill that would run.
  6. #166
    Dec 2006
    603
    Quote Originally Posted by Fixittt View Post
    Thank you! Here is what i have so far.
    http://forum.bugattibuilder.com/phot...s.php?album=27
    There are plenty of single cylinder plans out there. Start cutting. Until 6 month ago i had no idea what i was doing. Every time i make a part i learn something new. Bought the machines in April and started the engine in june
    Try the wobbler. It's a small steam engine that can be run on compressed air. Plans are around for free.
  7. #167
    Jul 2006
    887
    Steve that is simply beautiful! So umm... when your done... can i have it? LOLOLOL
  8. #168
    Dec 2006
    603
    You can have a copy of the plans that are half done.
  9. #169
    May 2006
    138
    Hi fixittt.
    I agree with Steve, the first thing to make is a wobbler. I have made quite a few of these, just recently got my workshop back up and running after several years of inactivity so am designing / making one now. It's a very simple engine and I'm about half way through it so when it's finished and tested I'll post the plans up on here in the Steam engine section if you like, see what you think. There are modifications you could make to make it even simpler as long as the critical dimensions are kept.
    Nick
  10. #170
    2139
    Eric
    Correction. That should read "Doubling up the engine could make it overwhelming for me"...
  11. #171
    2139
    Well, a new job and an addition on my home later and I am back at this project.
  12. #172
    Dec 2006
    603
    Nice work! Keep the photo's coming!!
  13. #173
    May 2006
    138
    looking good Eric, I've started on my hot air engine too but forgot to take photos from the start but suppose I could show what i've done so far!
  14. #174
    2139
    Last night I assembled the engine block with crank, rods and pistons, oiled it up and cranked it over on the lathe for a bit to loosen it up a little.
    I still need to make:
    Intake manifold
    Valve keepers
    lifters
    pushrods
    flywheel
    Fuel tank
    Carb is from an OS .35 glow engine for now.
    I also need to dream up some sort of ignition system. I will research an electronic ignition of some sort.
    E
  15. #175
    Dec 2006
    603
    E
    I designed this one that i did build and make sparks with. I intend to use it for my straight 8 by puting 4 magnets in the flywheel to make a spark every 90 Degrees. It will work with a standard automotive coil. I used a coil from a 66 caddy. One thing i did not try yet is changing the location of the magnet from the centerline of the crankshaft. Im thinking that will affect the dwell. If you make a distributor, changing the shape of the rotor vain cutouts will do the same thing.
    Picture 1 shows the test distributor i made. It is 1" in diameter
    Picture 2 shows the hall sensor mounted in the distributor.
    Picture 3 shows the circuit under test.
    Picture 4 shows the plugs that i tested with.
    Picture 5 is the circuit.
    Picture 6 is the rotor vain and magnet mount.
    Picture 7 and 8 are the final distributors, rotor and cap.
    Attached Thumbnails Attached Thumbnails DSCN0244.JPG   DSCN0232.JPG   DSCN0246.JPG   DSCN0275.JPG
  16. #176
    2139
    Nice, thanks for that.
  17. #177
    2139
    Here is the model of the intake manifold...
  18. #178
    2139
    Actual intake manifold. Pretty tricky part.
  19. #179
    2139
    Getting there....
  20. #180
    Dec 2006
    603
    Looks Great! Keep up the good work.
