587,228 active members*
5,408 visitors online*
Page 6 of 8 45678
Results 101 to 120 of 151
  1. #101
    Apr 2010
    215
    Re: Gully's new 3x3 steel CNC router build
    Hi Mactec54
    Thanks for your input.
    I have not wound any preload onto the linear bearings (I made sure the adjustment screws were loose) The only load on the bearings at this point would just be the weight of the gantry
    Gully
    Striving for medeocrity..and achieving high scores!
  2. #102
    15362
    Quote Originally Posted by gully View Post
    Hi Mactec54
    Gully
    I think you misunderstood what I said, the linear rails when you buy them com in different Preload levels most get a medium preload, is they are preloaded then the rail mounting have to be near zero for straightness in all directions or they will wear quite quick
    If the Linear Rails bearings have no Preload the your rail mounting does not have to be perfect it can be within the tolerance of that Rail Bearing set
    Mactec54
  3. #103
    Jan 2008
    1538
    He is using round supported rail.
  4. #104
    Jan 2007
    626
    Finally pulled the finger out and picked up the slotted duct.:banana:
    To celebrate the occasion, today I banged in all the AC side of the electrics
    Attachment 459382 Attachment 459384
    Have tested it for correct switching, continuity, insulation and resistance and all is good so will be happy to power it up.
    Just need to fit some din rail end stops to keep all the connectors together properly.
    DC stuff next
    Gully
    An observation Gully.
    You are shorting all you Terminal Blocks using wire. Best practise is to screw in shorting links along the centre of the sections to achieve this.
    Your way will work ok, but there a higher ( abiet small ) chance of a wire coming loose only because there are more of them.
    A shorting strip also allow you to use both sides of the blocks, so you can save some room.
    That might not be a problem for you....lol Your way is cheaper!
    Steve
  5. #105
    15362
    Quote Originally Posted by pippin88 View Post
    Not a problem then, he has no preload to worry about almost anything goes for this type of Rail, as they normally have around .1mm clearance and some are adjustable
    Mactec54
  6. #106
    Jan 2008
    1538
    Yes. Fairly unusual to see someone shim / try to achieve precision with round rail.
    Looking good Gully.
  7. #107
    Apr 2010
    215
    Finally have had time to get back on the cnc build
    Control box wiring is completed apart from a couple of switches I have ordered
    AC side all tested and working as advertised
    limit switches, steppers etc have just been belled out at this point to confirm they are wired /operate correctly
    Still need to order a smooth stepper and get that installed to go much further with setting up the axis and getting movement
    All the cable drag chain is fitted as well and I've started on the spoil board. So progressing slowly.
    Attachment 460754
    Gully
  8. #108
    Apr 2010
    215
    Another job off the to do list.
    Spoil board base strips sealed and fitted and hold down track installed.
    The base strips will get a layer of black 5mm PVC board glued to it and that will then get leveled to become the machine bed.
    Attachment 461098 Attachment 461100
    Smooth stepper has been ordered so hopefully over the Easter break I can get that all working and have some moving parts to show off.
    Gully
  9. #109
    Apr 2010
    215
    Well my high hopes of moving parts over Easter came and went as Wifey had other plans for me
    But this weekend I had time to devote to making this bad boy move.
    Smooth stepper set up went well on the laptop. Had it playing nice with their recommended version of Mac3. (R3.043.062) Happy days!
    Configuration and general set up of the machine was going great till I tried to set up the steps per..... function on the motors. Then for some reason the software started doing really weird stuff.
    Changing the steps on any axis would drastically alter the speed and acceleration of it without input
    For one distance test it would move in the right direction then on the check test it would move in reverse for about 15mm and stop.
    Never had that issue with any of the other versions of Mach Iv'e run in my Joe's.
    I persisted for an hour of late afternoon head banging then decided it wasn't happening and that I needed to bin that version and give an earlier version a run. No love there either as the earlier version refused to see the smooth stepper
    So that was my Saturday ending in tears.
    Spent Sunday morning dumping and reloading software on the laptop. Found a later version of Mach 3 (.066) on Artsofts FTP archive page. So onto the laptop that went for a try.
    That appeared to do the trick (touch wood) as I managed to do the steps per inch function in about 10 minutes with no issues.
    So as of now I have control over the machine. It moves correctly. The home function works correctly and hopefully the steps per inch will no longer be an issue
    Slowly setting it up and trying not to break anything. Will try and get some video of it in motion next weekend if the CNC gods smile on me.
    Still have a fair bit of tinkering left to do but it looks like I should even make my unofficial 12 month time frame deadline on this build.
    Gully
  10. #110
    Jul 2018
    6462
    Hi Gully - Yes the "1 year" barrier is like the 1 minute mile and the sound barrier. I used to have 6 months in my head until I built two and realised to Design and Build a year horizon is better! It comes and goes as well... Its looking great! Peter
  11. #111
    Jan 2007
    626
    Have you always used Latops Gully?
    Some have horror stories from using, some have none.....
  12. #112
    Apr 2010
    215
    Hi Pete
    Thanks.
    Yes the year barrier is always flexible and is either based on time available or spare cash to throw at it. But dam, it does come round quick.
    Hi Sterob
    No I'm not a fan of using laptops for running a CNC. Give me a dedicated PC any day. The Dell one running my Joe's is at least 20 years old and hasn't missed a beat
    I'm only using the laptop as a stop gap measure for the initial set up to keep things moving along so to speak. I have just had no time to sort out and get a spare PC running to the required spec.
    maybe in a month or so I will have that sorted as well
    Gully
  13. #113
    Apr 2014
    432
    Getting there for sure youl have fun once your up and running , I have finally purchased a smooth stepper board after thinking about it too long now I can step away from XP yay locally sourced ,
  14. #114
    Apr 2010
    215
    Hi InMesh,
    Thanks for dropping past.
    Hopefully for you, It should be a pretty straight forward change over on an existing machine.
    I thought way too long about swapping over to a spindle from a super PID/ router combo. The 1st time it ran I thought why didn't I do this years ago.
    Gully
  15. #115
    Apr 2014
    432
    Yep I have had the water cooled spindle now for 6 years still going strong done a lot of work ,I would like more than 24k rpm for the 1mm cutters I use but I am happy with my lot .A small water pump with coolant tank and red coolant mix to stop the growth and corrosion all good .cheers John.
  16. #116
    Apr 2010
    215
    While my tidy up and to do list to finish off this puppy runs into 2 pages. The fact that it will reliably now move on all axis for me means the hard bit is done and dusted:cheers:
    And you also know that its close when you start spending your time adding on stuff that you might never use such as a laser x hair instead of working on finishing the to do list.
    Attachment 462386
    Also proof of life video as promised
    Still need to machine a few more bits and pieces on my Joe's, then I will be able to move the spindle over to its new home.
    so close and yet so far!
    Gully
  17. #117
    Jan 2007
    626
    Very nice.
  18. #118
    Apr 2010
    215
    HELP:drowning:
    Slowed to a stop as I have an issue with the Z axis
    Despite working correctly when I first set it up ie: went up when the up button pressed went down when the down button pressed
    Suddenly that stopped and now will only go in the down direction when either up or down is pressed.
    Wasn't sure if it was a stepper/driver issue, cable issue, software issue or something else. so I have been in fault finding mode
    actions so far
    Tested stepper windings and belled out cable found no issue.
    Swapped from laptop to a PC (was planning to do this anyway) and did a full clean install of warp9 and Mach3 then redid the setup from scratch : Problem persists
    Swapped out Z stepper driver for a spare Gecko driver from my Joe's and ran a new test cable from driver to stepper motor: Problem persists
    operated the Z stepper from the X axis driver (as X axis) : went up and down so motor ok
    So Iv'e ruled out software, driver, stepper motor and cable
    That sort of leaves me looking at the breakout board being were issue is lurking. So more testing to be done after work during the week.
    Suggestions welcome in case there is some setting in mach that I may have missed.
    Gully
  19. #119
    Jan 2008
    1538
    To confirm:
    Z axis moves down when you command down
    Also moves down when you command up? (Or does nothing when you command up?)
    Sounds like direction signal is not changing.
    Check direction signal wiring.
    Check pulse widths (some drivers require longer pulse widths for direction than step pulses)
  20. #120
    Apr 2010
    215
    Hi Pippin88
    There is definitely a direction signal issue going on
    Slowly working my way through everything and checking it off the suspect list
    Will report back with the cause when I have sorted it
    Gully
Page 6 of 8 45678
  1. Router home build Australia. Solid steel build
    By 80gus in forum DIY CNC Router Table Machines
    Last Post: 05-03-2020, 09:24 AM
  2. Diy steel router build
    By mkc2 in forum Australia, New Zealand Club House
    Last Post: 03-11-2014, 02:20 AM
  3. Steel 1.2m*1m Router build
    By Jtepper in forum DIY CNC Router Table Machines
    Last Post: 01-18-2013, 08:20 AM
  4. New 4x8 Steel CNC router build
    By Ernie34 in forum DIY CNC Router Table Machines
    Last Post: 11-25-2012, 01:41 PM
  5. First Router Build - 4x4, steel, R&P
    By cxixer in forum CNC Wood Router Project Log
    Last Post: 02-09-2008, 09:15 PM
