Originally Posted by
mactec54
Tormach added the G30 to help those that could not understand how to do simple programing of the standard G-Code format Tool call normally takes care of this ( T1 M6 ) or should I say ( M6 ) does all the work, it is convenient though, G0Z0. does the same thing also, G30 will only work on there control in this way, and could be a crash if used in this way in other controls, as a normal G30 is to move to a 2nd 3rd or 4th Reference Point in a normal control, this is rarely used in the real world, so may be why the chose the G30 for this task in there PP control
They could of kept it to a standard though by modifying the ( M6 ) if it did not do what they wanted, which would of been a better choice of codes to use
As an example Haas they have the ( M6 ) It Stops the Spindle, Stops the Coolant, Moves the Z axis to the Tool Change Position, and Orients the spindle for the Tool Change Keeps it simple and is a standard code that everyone uses
