Hi All
just brought a 100watt Chinese laser cutter (80 w) with a fault on one of the axis machine was cheap £100 and local I have the dongles for the machine but no software
so my choices are trying to locate software or replace control board as far as replacing control board is concerned I ok for x and y its the best way to control the laser that I'm not sure of
Or should I go with the origonal control board i would like to confirm the laser works ok before i go down the retro fit
All advice experiances welcomed
I should add that I normally draw in fusion 360 and have both Mach 3 and uccnc Licences
