588,619 active members*
4,443 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > Windows 10 forced update knocked Cjet Cerion laser offline- Help Needed
Results 1 to 9 of 9
    Windows 10 once again has knocked my cerion laser offline. IN the past, a work around to install unsigned drivers was needed. This time, it is giving me an initiation error on the scanner card. Anyone having a similar problem or soulution?
    Jan 2018
    1516
    Re: Windows 10 forced update knocked Cjet Cerion laser offline- Help Needed
    Quote Originally Posted by MarcCerionlaser View Post
    I didn't quite figure out how to fully disable windows10 updates reliably yet.
    I'm blanking it all together for my mill, back to windows7 for me.
    Apr 2005
    305
    Don't let a production machine to connect to interenet.
    Simple as that.
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
    Jan 2018
    1516
    Quote Originally Posted by ZASto View Post
    Simple as that.
    Isn't as easy as that.
    Sending g-code programs or whatever to the machine over the network. Is easier than messing about with usb sticks.
    The pc isn't even ever used on the web. Win10 just does it's own thing if it sees a connection.
    Win10 is s**t!!!!!
    15362
    You can always go back if an update has caused a problem, it you don't want to get the updates then don't have the computer connected to the internet, it won't update if it is not connected and then if you do have to you can choose if you want it to down load or not it gives you that choice
    So if you want to remove an up date go to settings
    Settings
    View Update History
    Uninstall Updates
    Mactec54
    15362
    Quote Originally Posted by dazp1976 View Post
    Win10 is s**t!!!!!
    You have a choice to let it down load or not and if it did mess anything up you can remove the down load very simple
    Mactec54
    Apr 2005
    305
    Win10 is s**t!!!!!
    You can have your production computer connected to your LAN without been able to connect to "outside world"
    May 2024
    Which Version of Windows 10 (Build) did you use previously and which one did cause the problem?
    I am currently trying to set up a Windows 10 System and can't get it to work. It shows a similar error message you described...
    Aug 2006
    142
    Set the default gateway to 127.0.0.1
    "Teach the ignorant, care for the dumb, punish the stupid."
  1. Need help! Repair/Service of Cerion C-Jet2 3D Laser engraving machine
    By 3Dlaser in forum Want To Buy...Need help!
    Last Post: 05-16-2024, 04:23 PM
  2. Windows Update Store Error 0x80D05001
    By Alonrney in forum Computers / Desktops / Networking
    Last Post: 08-19-2020, 03:04 PM
  3. Beware of Windows 7 update KB4088875
    By eldata in forum Mach Software (ArtSoft software)
    Last Post: 07-16-2018, 05:27 PM
  4. KmotionCNC... Did the windows 10 update kill you?
    By MadTooler in forum Dynomotion/Kflop/Kanalog
    Last Post: 07-21-2017, 12:46 AM
  5. Friggin Windows Update
    By JerryBurks in forum DIY CNC Router Table Machines
    Last Post: 10-11-2012, 06:05 AM
