587,661 active members*
3,411 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Occasional metalwork table setup
    Mar 2014
    25
    I have had a 1325 Chinese machine with a 4hp water-cooled spindle for 5+ years. My table surface is MDF with a vacuum hold-down because I mostly mill wood. I occasionally do small aluminum, and I just use some scrap plywood as a spoilboard.
    My machine came with a misting system, but I have never used it. When I cut aluminum, I just manually spray cooling fluid on it.
    I am finally ready to try cutting steel, but I need some sort or removable hold-down/spoilboard setup that would be better for smaller blanks and protect my MDF from the misting and cuttings. I am thinking I only need something about 2’ x 2’.
    Suggestions on what types of material(s) would be ideal would be helpful.
    Apr 2004
    5750
    Re: Occasional metalwork table setup
    Forget about machining steel on that thing. Aluminum is the hardest metal you can expect it to handle, and that's marginal. The spoilboard is the least of your problems. The frame lacks the rigidity needed, and the spindle is much too fast. Steel needs a slow spindle with high torque - yours is the opposite.
    Andrew Werby
    Website
    Mar 2014
    25
    Impressive how you can make such a definitive determination, sight unseen.
    Apr 2004
    5750
    Sorry, but this comes up a lot here. You've got a wood router like this one: https://www.alibaba.com/product-deta...540170041.html right? It's certainly more heavy-duty than most people's Chinese routers, but it's still a wood router. I believe it can handle aluminum pretty well, but they aren't claiming it can rout steel. That takes a whole different kind of machine. No matter what kind of bed you put on that router, it will still be a wood router.
    Andrew Werby
    Website
  1. Spindle occasional stutter
    By Yurtman in forum Spindles / VFD
    Last Post: 06-27-2017, 09:10 AM
  2. New to metalwork in general, and Shoptask specifically.
    By CrispyD in forum Shopmaster/Shoptask
    Last Post: 06-05-2017, 02:06 AM
  3. Metalwork,CNC machining,please give me advise how to do well.
    By youngchon in forum MetalWork Discussion
    Last Post: 09-30-2013, 02:19 AM
  4. 3D software metalwork
    By vmax in forum Rhino 3D
    Last Post: 05-29-2013, 12:20 PM
  5. Metalwork milling tutorial/beginners guide?
    By Parkham in forum MetalWork Discussion
    Last Post: 08-30-2010, 09:27 PM
