Re: Work Holding on a Taig Mill
I have used my taig for 10 years using these clamps , i don't remember what they are called,it is by a popular work holding company, several online stores sell them, i am sure someone here will reconize them. m tooling plate is 1/4" alum bar stock, 4inch wide, it should have been 3/8 because the screws hit the bottom and put the middle of the tool plate so slightly, so I have to do a fly cutter to level the plate off, the holes are are 1/4-20, 1/2" centers so I cut bar stock a lot so it is easy to change the clamps to the correct size. I have never had anything come loose. I make 2 part molds and my cuts are not very aggressive.
I can also put my 3" vice in and out using these clamps
David L. Aery
www.hooksolutions.com
