587,997 active members*
1,979 visitors online*
Results 1 to 2 of 2
    Jan 2007
    626
    Painting a metal framed CNC Router
    I assume that if a steel framed CNC Router, with machined surfaces, is to be painted, that the area under the linear rails is left naked,as it were, as the paint would make re-aligning the rails again difficult?
    If so, does one used anything under the rails to stop rust?
    Steve
    15362
    Re: Painting a metal framed CNC Router
    Quote Originally Posted by Sterob View Post
    Steve
    If it is a machined surface as it should be and the rail is correctly fastened then it is not going to rust, for piece of mind you could put an anti-rust oil or grease on the surface before assembly
    You try and paint first then machine any mounting surfaces
    Mactec54
  1. Custom steel framed cnc router for wood and aluminum
    By Roadsidejobshop in forum DIY CNC Router Table Machines
    Last Post: 02-20-2017, 10:36 PM
  2. Aluminium framed FEA optimized CNC router
    By PotatoMill in forum DIY CNC Router Table Machines
    Last Post: 07-06-2016, 01:28 PM
  3. ScratchPad - DIY Steel Framed 3x3 Router
    By amishx64 in forum CNC Wood Router Project Log
    Last Post: 01-03-2013, 03:47 AM
  4. 1st build: Bright orange steel framed router
    By basskitcase in forum CNC Wood Router Project Log
    Last Post: 05-13-2010, 09:33 PM
  5. long term stability of wood framed router
    By dave925 in forum DIY CNC Router Table Machines
    Last Post: 05-06-2005, 05:33 AM
