can you input T06 EOB insert and than M06 EOB insert.
is the cycle strat button still lit?
is the command execute and dissapear from screen?
What you have on parameter 240 to 242?
Also the floppy shows zeros for 240 to 242.
What I should look at is the parameters actually in the machine.
Since I didn't re-enter the parameters couple weeks ago, I don't know how to check the parameters in the machine. (My technician re-entered them).
What buttons do I press to check parameters in the machine?
I was thinking you need a subprogram 09001 for tool change but if the parameter is empty it seems that you do not need
did you tried another tool call?Maybe you have tool 4 already in the spindle and that is why the machine do nothing
i think for MDI comand is M06 ->Input,T01->Input
did you load all the diagnose or checked with floppy if it is corect?
diagnose from 300 to 600
Thanks mate. Yes i tried other tools but no go.
How do i get to the parameters in the machine?
