587,375 active members*
3,123 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > OSP5000M-G tool offset setup, MC4-VA
Page 2 of 2 12
Results 21 to 24 of 24
  1. #21
    Apr 2006
    824
    Re: OSP5000M-G tool offset setup, MC4-VA
    Quote Originally Posted by Superman View Post
    Brian...
    Stop playing with the cat, you know you end up with headaches
    Yes Steve, I know you are correct.
    He has the way of making a simple request for help into complex headache for sure!!
    All Guntis wanted to know was how to set a tool length and look at the stuff Kitty has come up with.
    Far out Kitty, let people learn the simple stuff first, all your clever stuff will come in years later as they gain experience.
    You are a clever kitty, but back off a bit.
  2. #22
    Jun 2015
    4156
    hey broby, i started after i saw that guntisk's questions was answered; my replies are for you mostly, but also for whoever reads what i wrote: should make him wonder about faster alternatives
    what happenes next ?
    ... beginers : such infos may seem interesting, but irelevant at this point
    ... veterans : many stick to classic methods, and, in time, their desire to do it different will get lower, as there will be other priorities for them; this happens mostly because of external factors, that don't sustain creativity
    is not the 1st time i talk about 2 keystrokes zeroing, or faster restarts, etc; if someone is used to go to offset table, call, enter, how could he think that there is a faster way ? but once you only start to think that way, new kind of ideas may appear of course, someone with experience, may say how much time do i gain ? for this instance, even if you cut default time in half (or even more), there is almost nothing ( kind of 5 instead of ~15 seconds ), but, overall, all these little nothings sum up ... background idea, is how to improve all the little things, and see the benefit of going that way
    about explaining tool setups, etc, thus about explaining common procedures, i recently had an idea how to make them shorter and simpler, and i will show this soon / kindly
    ps : there is nothing new in this; okuma has variables, apps store, api, thus all you need is allready there; just look that way is not needed to know how to create such stuff from 0; seeing what others have done, may make one have new ideas ...
  3. #23
    Mar 2009
    1982
    My £0,02 :-)
    Sure, it would be good to have nice layout with first things separated from advanced and top level tricks. The forum is good source of relevant advices, so it's good to have the subject discussed in details at one place. It should serve not as "single- use" advice only.
  4. #24
    Mar 2007
    84
    Hi!
    Sorry for not answering earlier- there were a lot of other things to do. After making a cable, finding appropriate DNC program, making some sort of postprocessor parody and setting correct parameters in OSP Im now able to send gcodes to OKUMA. Everything works very good. After a few attempts all that tool setting and offsets actually aren't that a big deal to worry about. I can only agree to others who have written here on forums- it however require getting used to. Actually it is very easy CNC system to work with.
Page 2 of 2 12
  1. Replies: 9
    Last Post: 04-03-2024, 09:33 PM
  2. Replies: 3
    Last Post: 09-06-2021, 03:31 AM
  3. Intial Tool Offset setup on 840D
    By D_Turner in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 07-30-2013, 02:13 AM
  4. Fanuc 6M-B Offset setup both work and tool
    By RAJCKAM in forum Fanuc
    Last Post: 08-18-2010, 06:17 PM
  5. part setup Z &tool length offset
    By boilerx in forum HURCO
    Last Post: 06-27-2010, 08:59 PM
