587,999 active members*
2,324 visitors online*
Results 1 to 2 of 2
    Bridgeport VMC600 - air leak or normal
    Just learning a VMC600 (yes, i know about 20years late)
    Two questions...
    1. Should air leak down the spindle all the time ?
    I could understand when it was spinning, to block coolant ingress, but mine is blowing a huge amount of air continuously.
    2. It's a Heidenhain controller
    How to perform a tool change using the ATC ?
    I see the code for it in some of the programs it has, but surely there is a manual button for this ?
    Feb 2005
    101
    Re: Bridgeport VMC600 - air leak or normal
    Q1: I don't know a lot about the VMC600, but I have a TC22 which I believe is similar in many ways. There is likely a separate pressure regulator for the spindle air purge which you can adjust. You should check what it is set to. I think the factory setting on my TC22 was 7psi. When I got my machine it was set higher than needed. Mine causes my 60gal compressor to run every 15 minutes or so when I set it to the correct pressure.
    No idea on Q2... someone familiar with Heidenhain will have to chime in!
  1. turret air leak
    By Sythe179 in forum Daewoo/Doosan
    Last Post: 12-20-2018, 06:41 PM
  2. Bridgeport VMC600/22 buffer batteries
    By HugoLargo in forum Bridgeport / Hardinge Mills
    Last Post: 12-04-2018, 03:16 PM
  3. Bridgeport VMC600 Gross positioning errors please help (done searches)
    By centoproject in forum Bridgeport / Hardinge Mills
    Last Post: 04-30-2018, 07:43 PM
  4. Bridgeport VMC600- machine parameter
    By GernotGoessler in forum HEIDENHAIN -> GENERIC
    Last Post: 04-19-2012, 05:46 PM
  5. Bridgeport VMC600/22
    By de_firma in forum Bridgeport / Hardinge Mills
    Last Post: 12-18-2011, 11:50 AM
