Re: Y-axis move to the left when press right
Originally Posted by
ahmedhamdoun
Hello Everyone,
I have a Chinese CNC cutting machine with a Panasonic servo driver and motor
Servo driver model: MBDJT2210
Servo motor Model : MHMJ042P1S
the Y-axis moves only in the left direction even I move it manually from the control unit when I press the keyboard right key the motor move to the left (and the left key work properly to the left)
I have changed the control unit and the same problem occurred
and all the settings on the controller are correct
please help what is causing this problem
There are two ways to correct this:
1- Change parameter on the CNC controller
2- Change parameter on the servo driver.
http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
