588,246 active members*
4,168 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Spindle grounding- manufacturer says to not ground
Page 2 of 2 12
Results 21 to 26 of 26
  1. #21
    Jun 2012
    153
    Re: Spindle grounding- manufacturer says to not ground
    If you want to call someone pathetic, it's best to learn how to spell if first , mr. perthitic. :wedge:
    a small voltage will not cause erosion of the Bearings
    Wrong. A small voltage can lead to a high current across a near zero resistance. This DOES cause problems on some machines, if you are unaware of that , it's probably because you are perthitic..
    I was replying to OP who says he was informed of a possible problem.
    A piece of paper that came in the package says specifically NOT to ground the spindle, otherwise damage will occur when cutting metals.
    This was nothing to do with "breakout boards" which actually means nothing in technical terms so I have no idea what you think gets blow out. I would not use a probe circuit without an opto isolator for exactly this reason. If hobbyists are connecting straight to an Arduino of something, they will have problems.
    Since you clearly have nothing to add to the discussion, I don't know why you bother replying except to be smart. Not that helpful.
  2. #22
    Dec 2003
    24220
    So why post you are perthitic. (wedge)
    Any Ac 3 phase motor driven with a VFD Drive produces Rotor Voltage, a small voltage will not cause erosion of the Bearings
    Perthitic ? New one on me! , is it as bad as Covid?
    An AC induction motor does not produce any real voltage in the rotor shorted turns it is extremely small, there is a very high current flow however in the the single turns of a squirrel cage rotor which produce fractions of a volt.
    Albert E.
  3. #23
    15362
    Quote Originally Posted by reg.miller View Post
    Pathetic, spelling is correct (nuts)
    ADJECTIVE
    arousing pity, especially through vulnerability or sadness.
    "she looked so pathetic that I bent down to comfort her" · [more]
    synonyms:
    pitiful · pitiable · piteous · to be pitied · moving · touching · poignant · [more]
    miserably inadequate; of very low standard.
    "he's a pathetic excuse for a man" · [more]
    synonyms:
    feeble · woeful · sorry · poor · pitiful · lamentable · deplorable · [more]
    archaic
    relating to the emotions.
    This was related to your political statement, nothing more, pathetic was the correct word
    Mactec54
  4. #24
    15362
    Really, you sure of this.
    You should know better than this, so you are saying the motor manufactures don't know what they are talking about. hint what happened to CMV.
    Mactec54
  5. #25
    Dec 2003
    24220
    You should know better than this, .
    I am probably perthitic ?
    Albert E.
  6. #26
    15362
    The least you could do is to spell it correct, as I was corrected, anyone can make a spelling mistake, who cares it got the message across.
    Mactec54
Page 2 of 2 12
  1. Grounding router spindle?
    By Mogal in forum DIY CNC Router Table Machines
    Last Post: 02-07-2022, 07:32 PM
  2. Spindle/machine grounding
    By amowry in forum Spindles / VFD
    Last Post: 02-11-2018, 05:23 PM
  3. Grounding a 2.2kw VFD spindle
    By DDMODS in forum Spindles / VFD
    Last Post: 07-21-2016, 11:28 AM
  4. Help!!! Touch probe grounding through spindle???
    By Momentz in forum DIY CNC Router Table Machines
    Last Post: 11-28-2014, 10:21 PM
  5. grounding question, PC case ground
    By Fiero Addiction in forum Waterjet General Topics
    Last Post: 08-16-2008, 01:40 PM
