587,999 active members*
1,853 visitors online*
Page 2 of 2 12
Results 21 to 40 of 40
  1. #21
    15362
    Re: Basic Wiring Questions for VFD
    Quote Originally Posted by RufusToad View Post
    Not sure but would not think you would know him.
    I have made a mistake in which I posted this on another thread and though it was in here but you are missing a big chunk of the puzzle. I am converting to a VFD / spindle and before this was being controlled by a SuperPID thus the reason for a C10 board. The PID was converting the PWM so I am sorry I really thought that was posted. I got a little confused because the PID board only turned on and off the spindle and for some reason I could never get it to work with PWM control.
    I am going to purchase the C11g which I hope is a direct bolt up replacement and I wire it up so I can tighty up the panel and not use a bunch of relays etc. Stay tuned I am sure I will have more questions.
    If he does some videos, I would know him.
    Yes, that board should work, but very poor information on the PWM setup, you will need a 12v power supply for that to work, so you may still have some problems moving forward
    Mactec54
  2. #22
    May 2021
    47
    Got just a first name and I will tell you??
    Hallelujah, after a long time of learning and scratching my head, I finally got it done!! It's just hotwired until my new board comes but with some of your help and lots of persistence, I can now control my new spindle with Mach. Still a little confused about a few things but I will learn later...
    Question
    Not sure I understand why I need 12v for that board (see attachment)? Can I use the 10v output on the VFD to power the new board if I need to?
  3. #23
    15362
    Question
    Yes, you could try the 10v from the VFD Drive, it may be enough, normally the PWM converter needs a little more voltage to give you the correct Analog output,0-10v so if the output is lower than say 9.8v you may need the 12v
    Mactec54
  4. #24
    15362
    Question
    The 5v you show is just for the Optos on the Breakout Board this has nothing to do with the PWM circuit
    Mactec54
  5. #25
    May 2021
    47
    Perfect. I believe I understand what you're suggesting. I am doing a spindle break in right now (6hrs) and I'm using 5v for the PWM to VFD so fingers crossed this will be adequate. Board comes Tuesday so I shall see.
  6. #26
    15362
    What spindle do you have that needs a spindle break in, they have sealed Bearing, there is nothing to break in.
    It is in the C11G manual so go through each section
    Mactec54
  7. #27
    May 2021
    47
    Ugra Spindle. They specifically have a break in procedure for their spindles.
  8. #28
    15362
    They are no different than any other spindle just more money, a low speed, run though at the minimum speed won't hurt anything.
    Just make sure you have the VFD Drive Parameters set correct, or you can do some serious damage.
    Mactec54
  9. #29
    May 2021
    47
    BReak in done. I sure hope I have all parameters set correctly. I have been through it several times now.
    Struggling to get a full 5v out of Mach and at full speed I am only showing 570hz and it should be 600hz
  10. #30
    15362
    What VFD Drive do you have??
    What Parameters have you set and what is the spindle name plate specs.
    Mactec54
  11. #31
    May 2021
    47
    I missed this post for some reason. So I have my new board wired and for the most part set to go but I wanted to ask a beginners question. On this C11G board the top row is for the relays and PWM. According to the docs it says pin 14 activates the relays so my question is, no wire actually goes to pin 14 or 16? Those pin numbers are to tell Mach right? and then when mach activates pin 14 it tells the relay on or off?? Lastly what config is given to Mach for the PWM? When I used the C10 board I gave an actual pin number but that is not present on this board?
    A guy does a great video on this board and doesn't mention a word how to configure the darn thing.
    http://cnc4pc.com/Tech_Docs/C11G-R9_USER_MANUAL.pdf
    Also in Mach the only way I could get the spindle to run was to uncheck the PWM box and check the step/dir box? Sorry just a little confused on this one. I can not figure out what to tell mach or where to hook a wire up from the mach signal or does it even get on and at this point I am truly PWM?
    I am using a Delta Fans VFD022EL21A VFD and
    Ugra Spindle
    Voltage: 220V/380V 3 Phase.
    Current 9.7A/5.6A
    Poles: 4
    Frequency: 0~600 Hz
    Speed: 0~18000 RPM stepless.
    Manufacturer Recommended Working speed: 3000-18000 RPM
  12. #32
    15362
    Ugra Spindle
    Current 9.7A/5.6A
    Poles: 4
    Frequency: 0~600 Hz
    As long as you are getting the 0-10v out of the Board for speed control it does not matter what you are using, step / Dir can be used. this would be unusual though as the board was asking for PWM connection. contact CNC4PC to see if he can answer as to why.
    Also, as long as the Relay is working when you use M3 that is all you need for the On / Off control, how you get there does not matter, although it should be better documented which nobody seems to do a good job of.
    What I saw in the documents is Pin 1-17 for the relays, so more confusion for you with different Pin numbers, there is most likely a simple answer though. that CNC4PC can help you best with this.
    Mactec54
  13. #33
    May 2021
    47
    Thank you!! You have hit the nail on the head. I will play around with some m3 commands tonight and see if the relays are triggered. It is quite blurry on configuring Mach to this board.
  14. #34
    May 2021
    47
    Well, I have got it almost all figured out thanks to some of your help, but I am running into 1 issue. I cannot get the output to VFD signal higher than 7.2v with 12v into the board and it is maxed out on the adjuster pod. I adjusted the voltage at MACH full RPM before hooking up VFD and I had 10v at the board and with the VFD's AVI to ACM unplugged but as soon as I put the wire back into the pin it drops to 7.2v so I am little confused on that.
    So, for some reason I still need to have the Dir/Step as you can see in the pic and I am wondering what the Step/Dir pulse with is in the plugins config?
    I did switch the step/dir back to pwm on the ESS config menu, but it has to be set to step/dir NOT PWM control on the spindle set up menu.
    BTW I did put the base Hz down to 100 as you suggested a few weeks ago and the spindle was hunting so I went back to 600. Not really sure what BASE Hz means
  15. #35
    15362
    If you are using Step/Dir, the PWM number is not used so your 600 is not doing anything
    It is strange that the PWM is not working
    You can disable Relays also as that is not used, in motor tuning did you move both sliders to the max for the spindle settings. and set Step pulse to 1 and Dir to 1
    Mactec54
  16. #36
    15362
    The step Pulse / Dir Pulse is directly proportional to the output voltage, so you may have to change these numbers to get the output voltage you need
    Have you set the pulley ratio?
    Mactec54
  17. #37
    May 2021
    47
    I have to back track on that one pic. I posted the wrong one and I just noticed it. sorry !!
    I am finally working in PWM and I have no clue how. I have literally worked on this possibly 50 times but for the most part I am set. '
    I rescaled my VFD to 7.2v at 100% which I am confused as to why such a large voltage drop but it's working.
    So this spindle is 18000 max rpm at 600hz. I am now there after I rescaled the VFD, but I am short on my midpoint voltage, and I only see 3.26v and it should be 3.6v. Is there a way to scale the midpoint voltage in Mach?
    I am also noticing a few status errors saying Too Fast For Pully Using Max... Using Max. not really sure what this means either.
  18. #38
    May 2021
    47
    Hallelujah I think I found it. Its not exact yet but I am getting better.
    I had the Pullys at 1 and MIN RPM at 3000 with MAX RPM at 18000 which is correct but I changed that 3000 to 0 and the mid point voltage came up almost .35v. I have no clue that was calculated in the equation, but it seems to be. I'm getting there
  19. #39
    15362
    I was just going to reply to have you check the pulley settings, yes that should be 0 and 18000 ratio 1. some have changed this ratio also to change the voltage output
    The voltage coming from the C11G must not be linear and definitely something wrong with the max 10v output.
    Mactec54
  20. #40
    Jan 2018
    1516
    Those C11G boards are stupid and overpriced.
    They look like they have a lot of functions but at the end of the day you still only have 12 outputs and 5 in.
    Jumpers and relays just confuse things where it's a case of, use pin no* for this or this but you can't do both!.
    You would've achieved exactly what you wanted using one of those <£10 5axis bobs you see all over the place.
    They're simple to wire and work. I used one for 5 years!.
    Those also can go up tp 24v power input for pwm control. With some drives 12v input to the controller is not enough for analog to work properly as you're finding out.
Page 2 of 2 12
  1. enclosure wiring questions 220v VFD + 110v DC power supply
    By thisispete in forum DIY CNC Router Table Machines
    Last Post: 02-01-2019, 09:37 PM
  2. A few VFD wiring questions....
    By Goemon in forum Spindles / VFD
    Last Post: 02-08-2018, 07:26 PM
  3. Replies: 0
    Last Post: 04-02-2015, 04:57 PM
  4. Newbie questions: Need drivers? Basic Wiring?
    By AKMike in forum CNC Machine Related Electronics
    Last Post: 02-22-2011, 06:24 AM
  5. Fairly basic questions re stepper motor wiring!
    By HankMcSpank in forum Stepper Motors / Drives
    Last Post: 08-22-2008, 09:58 AM
