587,081 active members*
2,697 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > PlanetCNC > Milling along the path PlanetCNC v. 2021.12.08
Results 1 to 5 of 5
    How to force a program to drive along the path ? On the left side of the drawing, place the path from Corel, on the right side of the drawing I put the actual path from planetcnc. I did not expect this Cutter diameter 3 mm.
    Mar 2017
    1328
    Re: Milling along the path PlanetCNC v. 2021.12.08
    G64 in g-code or disable blending in settings (Motion/Blend/Blend tolerance - set to 0)
    Thank you for your answer. I am asking for help. How to force higher speed during the spindle lifting. It's now that, speed down = speed up. How to increase the spindle movement (only speed up) to speed from option "motors->speed-> max. speed" or "motion->speed->maximum.speed". I want to save time, I'd like speed down = defined speed, and speed up = max . speed.
    Mar 2017
    1328
    You need to learn now g-code works.
    Speed in feed moves is set with F word. Traverse moves use speed set in Settings/Program options. In both cases maximum speed setting is also obeyed.
    Thanks. I know how it works. With several thousand lines gcode difficult to edit code manually. If that's not possible, i will go back to the old software, it is more efficient.
  1. Replies: 0
    Last Post: 09-09-2021, 09:58 AM
  2. Replies: 0
    Last Post: 01-27-2021, 10:01 AM
  3. Thread milling simulation [EdgeCam 2021]
    By lukasz2109 in forum EdgeCam
    Last Post: 01-15-2021, 12:00 PM
