The temp sensor is located in a few spots I've seen. There is a metal clip where the sensor is pressed into. It's a PEPI sensor on many and you wont get them to respond or reply. I tried and tried. What I can tell you is there are two types. Snap temp sensor and a creep. You'll want the SNAP sensor, and it can be tested w/ an ohm meter and a heat gun. (but be careful and don't burn it). Here is a post where I outline a replacement I used. https://tinyurl.com/yc89vvm3 there is the IGBT for RegEn also utilized in the mix, but your situation does sound like a possible SNAP action sensor issue or even a bad or possible wire rub or snag... Good luck w/ it.
