588,655 active members*
5,865 visitors online*
Thread: Jumpy X Axis
    May 2021
    47
    Jumpy X Axis
    I was wondering if anyone has experienced a jumpy axis on a router table that was caused by the Motor Tuning in Mach.
    Could a miss tuned motor somehow cause a slight jumping effect that is more pronounced with faster speeds?
    I am pretty sure there is nothing with the gears or Nema 34 motor. It just seems as if there is a possible internal fight happening, but I could be crazy as well.
    I am not losing steps nor is there any kind of noise, but you can see the table shake slightly.
    The noticeable shake is at a speed of say around 120ipm but if you slow down to around 60-80ipm it is a lot smoother.
    Nov 2013
    4621
    Re: Jumpy X Axis
    if its not losing steps, it sounds like it close to doing so. I would guess its a mid-band resonance. 34 size steppers seem to be prone to this kind of vibration.
    What micostepping regime are you using?
    Craig
    May 2021
    47
    Re: Jumpy X Axis
    Hi Craig,
    I figured somebody might have some great info on this forum. It is very odd, but I did notice something tonight as I was changing tools, I use my remote pendant or arrow keys and it is moving as smooth as a baby bottom.
    I will also say I am noticing this more on 3d/STL type carvings like a waving flag type carve. I took a screen shot of the motor steps. Y is very similar but doesn't seem to be jumping.
    Do you think I am off on the steps or maybe the velocity is to high?
    Im using surestep motors and Automation drives.
    Jun 2010
    4262
    Re: Jumpy X Axis
    Cost you nothing to slow down both speed and acceleration a bit for a test run.
    Cheers
    Roger
  1. Jumpy feed in all axis during G1, smooth feed during jog
    By x69rzx in forum Machines running Mach Software
    Last Post: 03-25-2021, 04:44 AM
  2. 1986 Mazak QT10N ATC/MC with CAM T3 control, jumpy axis motion
    By wozzwinkl in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-09-2021, 01:21 AM
  3. Bit loud, and jumpy...
    By liltritter in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-30-2015, 08:15 AM
  4. Jumpy stepper
    By momojoey in forum CNC Machine Related Electronics
    Last Post: 06-27-2014, 03:17 AM
  5. Fanuc 5T Jumpy? /Bad Backlash
    By John3 in forum Fanuc
    Last Post: 03-19-2007, 12:59 AM
